8 members (Jon G4LJW, MATTMOG, Luddite, Tom Sayles, Hamwich, DCH, Davetherave, RedThree), 207 guests, and 126 robots.
+8Rich 78
Topics49,872
Posts837,687
Rudolf
Drove home last night in horrid weather in the dark. Biggest problem was trying to avoid being blinded by the lighted switches in my +4 by the time I had the heated windscreen and rear foglight on. They are just too bright.
The dash rheostat adjusts the intensity of the clocks, but not the illuminated switches.
Before I start tearing in there, has anyone tried either a bulb swap or wiring them for rheostat?
cheers, Colin
Rog Offline
You could pop the tops off the switches and add a thicker filter material.
This link might help.
http://www.talkmorgan.com/ubbthreads.php/topics/141346/1
Roger
I guess that you have the push Switches made by eao. They directly mounted to circuit board which makes is a bit challenging to connect them with the rheostat. But you can Change the "bulb" or LED ínside.
BR
Christian
Switch demounted
Switches
Backside circuit board. The black "screws" fix the Switches to the board.
From the eao catalog.
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
Another solution would be to Exchange the visible parts against the newer ones used since 2008. That's what minikeefy and myself did. I can send you descrbition by PM if you like to.
BR
Christian
Before
After by daylight
After by night
Christian, understnading this is a PCB installation with LED's, what you have done looks like the answer!
Can you PM me details please?
cheers, Colin
