9 members (MJF, JoeSpeetjens, RichardV6, John Winn, SailingTom2, Strathaven, uvk33n, Joske Vermeule, Stevo666),
261
Topics49,911
Posts838,146
Posts: 108 |
The dealer says we need a new rear tire. Can't imagine why  Any suggestions for what to get?
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Something black and round.......
Posts: 1,740 Likes: 57
Posts: 1,740 Likes: 57 |
There's already a long thread about this topic! Search for 'Wot rear tyre' (sorry I can't work out how to insert a direct link...)
Andy
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Something black and round....... A Pontefract cake?
Posts: 508 Likes: 1
Dreiradschubser Talk Morgan Regular
Posts: 508 Likes: 1 |
The dealer says we need a new rear tire. Can't imagine why I have had the same problem, there must be some strange small animals in my garage to eat up the tire during my sleep  Achim
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
I just went through the tire selection business. I simply went on "Tire Rack", entered the size (175/65/15), looked at what they had and picked one based on price and performance. It is a KUMHO and is out in the garage along with a package of dyna beads awaiting my attention. I think most modern tires in our size for the rear will work fine. It is front tires you really want to be picky about as there is not a lot of grip up front.
Posts: 655 Likes: 1
WW11 MOG Talk Morgan Regular
Posts: 655 Likes: 1 |
Why not try a lower profile?
Just fitted a Yokohama A Drive to mine. Its a 175/55/15 and the M3W feels much more lively and you can generally drive in a higher gear than you might be used to. Ok, you lose around 5mph at the top end, but how often do you go there?
I fitted mine primarily for improved acceleration and drivability in the higher gears for hillclimbing and racing, but I'm leaving it on for road use also, through the summer at least. It drops the back end by around 20mm
I did consider a 50 profile, but found there was very limited tyre choice and I also felt the back of the car would drop to the point where it might be too low for general road use. If you have adjustable shocks, which I don't, you could jack it up I guess
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I have just replaced the original Yokohama with a Kumho as well, a KH27 Ecowing. It was slightly cheaper than the Yoko, has a fairly symmetrical tread design, better wear and wet grip figures but most importantly, it was in stock on the shelf. The Yokohama lasted just over 6000 miles. The front Avons look to be lasting forever now that the steering geometry is sorted, hardly any wear since then.
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
I think most modern tires in our size for the rear will work fine. It is front tires you really want to be picky about as there is not a lot of grip up front. So totally agree. The rear can be a hard rubber for longevity with an ability to scratch on command or a soft tire for grip and a short life. Fronts, however, are absolutely where it's at! I added Blockleys and they are a vast improvement over the stock Avons but, seriously, if I wanted a race worthy M3W I'd rip off the front fenders and get different sized wheels and some serious motorcycle tires! Fortunately sanity checked in and told me to sit down. I would get into trouble. I know me.
Posts: 655 Likes: 1
If you remove the mudguards and change the wheels to fit grippy motorbike race tyres you are in Racing class. Would have to spend a lot more money on the engine then to be competitive.
I run in Standard Class and nippymog is in Touring Modified due to his upgrades. You pays your money and takes your pick...but whatever class you're in, its fantastic fun doing competitive motorsport in the M3W (5 Speeder)
Its our race debut on Sunday at Cadwell Park...which looks daunting!!
