2 members (ChrisConvertible, Saxonian), 349 guests, and 38 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
Page 257 of 1,342 1 2 255 256 257 258 259 1341 1342
Thank you all so much. It really makes me humble to know there are people out there who care.
Best Regards
Lang may yer lum reek
Drive on the Wild Side
Hi Jays, if the cylinder has seized then the drums will be hard to get off. I had this on Rosie. You need a piece of hard wood on edge of drum and firm whacks with mallet. Alternating each side, it should come off. Probably best to get new cylinder at factory in preparation, it's bound to be rusted up and seized.
Adrian
We're a community Bob and it makes us all realise how small our troubles sometimes are in comparison.
Roger
Bob- very good news. I hope things continue to improve.
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
Off to the opticians for the usual 2 year eye test in Chesham.
C 12 miles going on 40 I guess if I take the long way
Ray Offline
Originally Posted By Jays
Took the Roadster out this evening for a bit of braking practice prior to MOG15. It's getting easier but looks like one of my rear drums is binding swear I only had the brake cylinder replaced last summer as well! Tried to get the drum off and it just won't shift. Looks like it might be the Z4 for the event after all frown
Jays hit the face of drum fairly hard with a soft mallet, for some strange reason the drum bounces off.
Discovered out of frustration? smile
Tried that yesterday evening Ray....the mallet just bounced off! I took the car out for a spin this morning on mixed roads and lo and behold, the brake seems free and there is no heat in the wheel unlike yesterday. So....fingers crossed!!
Did it get put away damp or with the handbrake on? Perhaps rusted on and the mallet broke up the rust?
The handbrake is never used in the garage Richard. I suspect that there was some corrosion around the cylinder and with use it has freed itself. When I get time I'll try again to get the drum off and give it a good check over.
