6 members (MartO, BobtheTrain, gomog, JohnHarris, Moggo, Grumpy2), 418 guests, and 71 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
Posting Desperado
Posting Desperado
Yes not far off looked like one of these modern green statues. I was covered with cement , grass cuttings, leylandii clippings and compost I could have hid from the SAS with ease . farmerTM dont have a tramp one .
Originally Posted By Ray
Originally Posted By Jack The Lad
Its SUMMER why do you need a heater swmboand I worked in the garden all evening me pointing the old wall with just a tee shirt on .
exhibitionist. shocked2
Originally Posted By Hamwich
As my car is quite old, I was able to replace the crappy old heater box with a stainless job from Heart of England. All it has instead of a filter is just a network of holes drilled in the top to stop debris, small mammals, and such stuff getting through. Is a filter really necessary?
Good question
My heater box is the original from 2000 and the air intake inside the box is on the back under a aluminium lip so without a filter it is unlikely that debris would get down into the cockpit inlet system ( I use the word 'system' lightly and loosely) so maybe the filter is unnessary
Any thoughts ?
Mine ('86 4/4) doesn't have a filter. It has some rather crappy strips of foam around the edges that theoretically close up to the bonnets and stop the hot air from the engine getting in through the intake [note to self: must redo those at some point, maybe it's time to play with some neoprene], but inside that is just a gaping maw with nothing except the louvres above to stop leaves or rodents getting in. I can't say I've ever had a mouse land on my ankles while driving, though, so I guess that hasn't (yet) been an issue...
Good question
Any thoughts ?
Doug
1985 4/4 4str, Jubilee Blue
Dear Hamwich,
I own a 1991 1600 4/4 and my heater box is rather worn out...rubber is torn and the small iron filter is rusty.I use some fish tank filter asfilter on top of the iron filter.
I am a Begian and would like to buy a new one.
Do you know were i can find one....if possible Original .
thx in advance
Herman
Antwerp Belgium
Originally Posted By herman poschet
Dear Hamwich,
thx in advance
Herman
Antwerp Belgium
Hi Herman,
If you want an original heater box, then I would suggest you call Melvyn Rutter. If anyone could get you one, he could.
okč thank you Tim H.
