Topics49,848
Posts837,406
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
I usually use ACF 50 down the beading on my Mog's, do Bilt Hamber do a better product for this Tim? They do something called Ferrosol which is the same kind of thing, but I use ACF50 like you, Brian. I think it's probably the best product out there for this application.
Posts: 3,643 |
ACF50 has very good creep properties, you not not need to use lots, a little goes a long way.
Posts: 7,363 |
I usually use ACF 50 down the beading on my Mog's, do Bilt Hamber do a better product for this Tim? They do something called Ferrosol which is the same kind of thing, but I use ACF50 like you, Brian. I think it's probably the best product out there for this application. Thanks Tim, I'm a bit of a technophobe so appreciate the advice. Thanks also Wirewheel, I'm sure I use too much - just to be sure!
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
ACF50 has very good creep properties, you not not need to use lots, a little goes a long way. Another vote for ACF 50, used it on Aldermog, now used on Tarka. A little goes a very long way!
