7 members (Fuel.inj, Vansrv6, bmgermany, RichardV6, Alan Patterson, GrumpyPa, JohnHarris), 166 guests, and 65 robots.
+8Rich 77
Topics49,870
Posts837,669
Rudolf
Page 3 of 4 1 2 3 4
Ray Offline
Stewart why do you have to change the tonneau t0 fit aero screens? Mine fits the same.
The cover fits right up to the inside of the windscreen with a very small gap
There are three fasteners just infront of the screen - one is certainly in the way and would have to come out, not sure on the other two as they might be to the side of the where the aero screen feet would be but not checked
The cover would have to be altered, cut back to accommodate the screen feet and the fastening altered
jbk Offline
Stewart, this is what a short door looks like with aeroscreens and a tonneau cover.
Turns up the leading edge a bit but not worth cutting it about i reckon, unless you are really fishy, sorry, fussy…..
Aeroscreens on short door.
1993 T16 +4 Lancia Blue.
That is how mine used to work to. It never bothered me
I cut and re trimmed my tonneau to fit around the both the aero screen feet and also the scuttle mounted rear view mirror I fitted.
If anyone is thinking of fitting aero screens to post 2009 cars, be aware that there may not be any metal under the padding where the outer mounting foot goes! The metal scuttle has three twopence sized holes cut in it to provide a crumple zone.
Thanks
no you are right it doesn't look too bad - maybe I'm overthinking a complication
Richard, That is an interesting set up: on mine, if I have both screens erected there is quite a bit of buffeting but hardly any with just the driving side up.
Or you could mount them further forward( see earlier photo) as I have but then you must remove them to erect the full screen - but then I've only done that once.
I put a post on here of fitting them to my +4 if it helps several years ago if it helps
Thanks meabh that certainly wouldn't have occurred to me, I'll bear the buffeting passenger side in mind, making me think more about just mounting the one right now.
Page 3 of 4 1 2 3 4
