Topics49,868
Posts837,640
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Thanks for all your suggestions, Hamwich was the closest! I had to remove the door panel or card held in place by about 8 small phillips screws, unscrew the 4 dome nuts(7/16th) and that allowed me to swing the door open but leaving the mechanism still attached ty the B post. I then drilled the 4 blind rivets on the back of the lock assembly, removed the backing plate and manually release the catch. The metal cam on the small locking lever had got jammed, so a good lube and put back in the reverse order. Total time, about 1 hour plus. There is always something to do on a Morgan! Well done Glad it's sorted Nothing is ever easy and straight forward on a Morgan
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
Thanks for all your suggestions, Hamwich was the closest! I must have pressed harder than you - it worked for me.
Ken
Posts: 12,260 Likes: 319
Posts: 12,260 Likes: 319 |
Glad it's sorted. Lesson of the day: don't ever bother to lock your doors
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Posts: 5,210 |
There isn't much point really is there!!
Posts: 15 Likes: 1
Posts: 15 Likes: 1 |
Same happened to me today! In busy public car park in N Yorkshire. Visions of trying to scramble across from passenger side. I opened the window, wedged my knee against the door, wiggled the key and hey Presto! It works! Thankyou!
