1 members (Saxonian),
354
46
Topics49,897
Posts838,017
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Looks a very nice job,mate. When you swap it for that Lotus give me a call.. PS - Get your screw slots lined up, man..!!
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
PS - Get your screw slots lined up, man..!!  That's the first thing I noticed but didn't want to say
Posts: 14,009 |
I've the same problem....as the screws fit directly into the hub, you can't easily line them up. It's different with nuts and bolts!
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
I had the same thought, maybe a little neurotic....? But as there's a perfect explanation, then it's okay!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
I've the same problem....as the screws fit directly into the hub, you can't easily line them up. It's different with nuts and bolts! Ah Must be different to mine - I've got bolts that go right through with nuts at the back so can be lined up
Posts: 1,653 |
Jays kindy jumped to my defence!
Goes into a captive boss, no adjustment!
CDO like OCD with the letters arranged alphabetically!
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
You're not ocd enough if you can't sort this out. Bumble was like this and all you need to do is swop the screws around until you get decent alignment. The threads start in different positions relative to the slot so I solved it in a few minutes. Alternatively source some crossheads to double your chances or Allen headed set screws.No excuses.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Very sad.
.....Alternatively source some ....Allen headed set screws.No excuses. Of course.. Balance and universal harmony can now be restored
Posts: 1,299 |
 2013 M3W # 793 'Mosquito'
