5 members (Pittsartist, TalkMorgan, banbury, Craig Jezz, JohnHarris), 214 guests, and 35 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,046
Hello guys,
just the weekend I realized a screw on the frame of my 4/4 Sport side screen has come off :-(
I can not figure out if the screw is metric or not, and its correct dimensions.
Maybe someone could fill me in here?
Thanks a lot,
4/4 Sport 'Sports Red' (12/2009)
Greetings from Switzerland
Wilhelm
Hi Wilhelm,
I can't confirm this but I suspect that they are metric screws.
The earlier 'short' sidescreens used BA threaded screws.
Go to a hardware store and try some metric screws but when you buy, get stainless steel screws.
I hope that this helps.
Regards, David.
Given that it has a pozidriv head, I'd guess metric too. Probably M5 or M6.
Easiest way to confirm size is to try a 'known' bolt thread. And if you unscrew the corresponding screw from the other side screen, you'll find the length.
cheers, Colin
The sidescreens on my 1986 (short-door) car use M5 screws in that location, I can't imagine that they'd be different on a long-door sidescreen.
I can't help with the length as I have inner upholstered panels and the screws are longer than standard. My guess at the stock length would be 10 or 12 mm.
Formerly known as Aldermog
Hi Wilhelm,
I had the same experiencewith my 2014 car. I replaced it with a semi countersunk screw from my "collection". It seems to be a M5 Fine thread, but i'm not 100% certain. I'm going to williams Morgan tomorrow and will try to remember to ask if they have a replacement of the correct countersunk size.
E
E
Originally Posted By Eddie Cairns
When the size in known
At 99p each I'd just get a few of each!
Might I add a drop of loc tite on the thread may prevent a reocurrance
Morgan Roadster 3.7 2012 Spruce Mica Green Saddle Brown Interior
I was going to suggest the same...all mine were loose when I bought my car and one has dropped out and disappeared!
just to add confusion to the mix mine are 5mm across the threads making them M5 and 12mm thread length and 15mm total length (mine has sidescreen liners too)
Last edited by milligoon; 14/07/15 10:41 AM. Reason: measured wrong screw first time!
Mark - No Longer driving
