Morgan Aero 8
9 members (sewin, Jon G4LJW, linklaw, nick w, MATTMOG, Mogdavid, High Hamster, Grumpy2, bmgermany), 192 guests, and 37 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,041
#28855 22/04/09 06:02 AM
scottie Offline OP
my aero 8 carpets/floor mats the factory fitted ones slide all over the place, they have floor studs which are meant to keep them in place however seem still to move which is annoying and can get in the way when driving.
Has anyone came up with a solution to this which may help.
scottie #28863 22/04/09 07:52 AM
Mr Fezza
Mr Fezza
Double sided carpet tape?
Maxxed out!
mr_tony #28867 22/04/09 08:20 AM
Or double sided velcro - sold at most larger hardware shops - is another good bet, especially if you ever lift the carpets to clean under them.
If not, mr-tony's suggestion is better as it will lay flatter.
Simon #28873 22/04/09 10:38 AM
Mr Fezza
Mr Fezza
Carpet tape might leave a mark on the carpet below though.. Just a thought..
Maxxed out!
mr_tony #28923 22/04/09 10:28 PM
Tony, I think that's not a problem as carpet is straight over the ally floor.
Aero 8 GTN. #10
Shooter #28938 23/04/09 10:21 AM
There's a product for use on food trays to prevent 'plate slippage'. I'm not sure where you could buy it - maybe a 'kitchen shop'. You buy it 'by the roll'. We have some and it's a beige diagonal pattern soft plastic with holes. It's very good at holding plates on trays, so I'm guessing would hold carpet. Alternatively a thin rubber mat would probably do it. laugh2
DaveW #28967 23/04/09 07:59 PM
We used a product used to stop mats sliding on wooden floors - John Lewis I think sells it.
Worked quite well and removable. read
New joints for old!
