8 members (RichardV6, DaveW, nick w, Alan Patterson, hugo, +8Rich, ScotiaSteve, Pittsartist), 192 guests, and 56 robots.
+8Rich 81
Topics49,859
Posts837,507
Jonny72
#288782 16/07/15 12:59 PM
Hello
The spring on the clutch pedal of my 1991 4/4 Morgan has come loose.
Iam able to shift the gears but... is it dangerous to drive with it please ??
THX
If you mean the spring immediately behind the pedal it's a straightforward fix. Without it there shouldn't be a prob in my opinion unless your foot rests on it, in which case the usual results.
Nick
Hello Nick
Thanks for your reply...difficult to get to...i think the small clamp on the pedal retaining the spring is broken.
Herman
Antwerp
Belgium
There was an old thread on this a couple of years ago, I think... might be some useful advice in there...
yes, here it is http://www.talkmorgan.com/ubbthreads.php/topics/140492/
Doug
1985 4/4 4str, Jubilee Blue
Mine's been broken for over a year but the clutch pedal returns OK so have just left it
I've got a replacement spring from Melvin Rutters but it looks like too much hard work for the Summer
I will get around to it this Winter
okč....i will check again i think the spring is okč but has come off the pedal. I can shift okč but have to do a rally in Greece early september so want it repaired
thx for yr.input
Herman
If the pedal details are pretty much the same as a 1972 car, pretty easy to get things apart and replace the broken spring.
It does depend on the mechanism, but the pedal return spring potentially ensures there is no pressure on the release mechanism. So the bearing and release fingers could get a bit of wear; or not.
So I'd replace the spring, but it may not be a urgent job.
Both springs have been changed...the total mechanism cleaned & greased so shoul be ok now.
Thank all.
