3 members (mph, PaulV, jejemek),
186
38
Topics49,844
Posts837,360
Posts: 4,896 |
What you need is a modern Roadster with an A and B odometer, then you can use the B to keep check on the Grease regime. Time to upgrade.
Adrian
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
Why not just grease every 1000 mile increment? Like, 5000, 6000, 7000 etc etc.
Posts: 4,896 |
Why not just grease every 1000 mile increment? Like, 5000, 6000, 7000 etc etc. Well I personally do not think every 1000 miles is sufficient, certainly not with standard pins. Also I have noticed the frequency is different depending on the thickness of the grease, hence why I am trying something new.
Adrian
Posts: 22,357 Likes: 353
Posts: 22,357 Likes: 353 |
Adrian - if you still have MMC steering bearings with rubber covers, they are very sticky. I wonder if your perception of stickiness after a certain point is the steering bearings. Once you grease, they will get a shot of grease but it will soon lose effect. When you do your pins get Mulfab bearings. Quite honestly my Roadster steering now is really (unbelieveably) light except at parking speeds.
Posts: 4,896 |
Yes I also do not like the factory bearings and suspect that this is part of the issue, small balls with lots of thrust on them is never good, especially if not we'll lubricated.
I intend to replace with better springs, probably from Suplex with a higher lb rating and shorter bump stops carefully setup so that they are not pre-loaded, and Mulfab bearings, and hardened chrome pins and the better bushes. So with any luck I should get the best I can from a traditional type set up. So effectively combining what I learnt from my +8, and what others have done and advised. The end result should be a Morgan that handles well is reasonably comfortable and has predictable front suspension/damping. The shock absorbers are adjustable AVOs. IMHO for what I want it's about the best you can do. Rear end will be stabilised with a pan hard rod, preferably with one like I had on the +8 from Mulfab, as I now that design works well, and maybe another anti-tramp bar if I join the speedmog gang in the future.
Adrian
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
These "new" Roadsters seem more trouble than they are worth Adrian
Posts: 4,896 |
These "new" Roadsters seem more trouble than they are worth Adrian They all do that, it's a Morgan sir!
Adrian
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
. Yes I also do not like the factory bearings and suspect that this is part of the issue, small balls with lots of thrust on them is never good, especially if not we'll lubricated. I've never really had that problem with mine
The ones on Bumble were pretty much 'stuck'. They were even hard to turn off the car - it's the rubber cover which seems to be the problem, and you know how much I love rubber accessories.
Posts: 347 |
Morris K323 Blue Grease £9.95 + £4 postage on Ebay and only £3.02 + £4.74 postage (up to 3 tubes) TFM Farm and Country etc
2014 +4, Le Mans Blue / Magnolia "Meg" the Mog
