Topics49,868
Posts837,633
Posts: 152 |
I have just ordered a new scuttle mirror for my 2011 4/4 from HoE.
The windscreen mirror fell off and I never really liked it.
I need to remove the windscreen to fit the mirror and would appreciate any advice as to how to do this. I can't locate any old posts.
I also wonder why I have to cut the dash padding away, rather than just use longer screws.
Any advice appreciated.
Jeff 2011 4/4
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
I don't have a heated screen, so i will leave that answer to someone who does, but the reason you have to cut the dash padding away is most likely to reduce vibration as the the padding will make this worse than it is when screwed direct to the scuttle.
I prefer the scuttle mirror and it is essential if you have aeroscreens, but it does create a blind spot as its around eye level, you might find yourself looking round it from time to time Regards john k
1993 T16 +4 Lancia Blue.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Try longer screws first ,nothing to lose.
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
My previous Morgan , a 4/4 had same mirror, don't recall any of the dash padding having to be removed..
Posts: 152 |
Thanks very much guys.
Regarding removing the glass with frame, it looks like just removing 4 screws either side and lifting out the frame, leaving the alloy supports in place?
Then easing the frame upwards out of the rubber sealing strip and hoping that it is not stuck in with some type of sealant?
Jeff 2011 4/4
Posts: 132 |
I fitted a dash mounted mirror once. I screwed straight through the padding with no trouble.
On Ruby's recent refurbishment, however, I reverted to a screen mounted mirror. I found that the lower placement of the scuttle mounted mirror tended to get in way.
YMMV.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Mine was screwed through the padding. But with the heated screen you need to make sure you don't break the heater wires.
Posts: 152 |
Thanks John I'll go carefully Jeff
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
The closeness of the mirror base to the windscreen may make it hard to get a screwdriver to locate? A stubby may work, or a right-angles one. Phillips/cross head screws would make it easier than plain slot headed screws. No need to remove screen then.
Thanks John I'll go carefully Jeff Be carefull drilling the padding, it might try to tangle on the drill bit.
