Goodwood
Topics49,931
Posts838,506
Posts: 22,385 Likes: 358
Posts: 22,385 Likes: 358 |
Last Sunday I noticed a creak coming from the base of the nearside screen frame. It could be reproduced when stationary by moving the nearside frame slightly fore & aft. It was a dry creaky noise. I squirted some silicon lube in the corner and tightened the fixings, and hoped......... But today is was still there after 230 miles! - a good run out. It turned out to be the bonnet creaking on the bulkhead tape. So I've applied some silicon lube to the tapes and fitted a couple of small neoprene buffers on the rear corners. I can't make it creak now in the garage, but haven't had time to get back on the road.
Posts: 1,597 |
Dave
Do you think this will also work for my knees ?
When I read your post I was reminded of a dry creaky noise with a bit of movement fore and aft, I thought a bit of silicon and some neoprene on the corners sounds just the job.
I have the perfect solution for your creaking knees Lightsphere..... Ask the Doc if he can fix you up with a nipple or two....... Preferably on the joints, but be imaginative.....
NGUNS!! Part of the Furniture
Posts: 4,564 |
I have the perfect solution for your creaking knees Lightsphere..... Ask the Doc if he can fix you up with a nipple or two....... Preferably on the joints, but be imaginative..... I believe our own Orthodoc offers this as a bespoke service with special discount for Morgan owners
Cheers
BtG
Posts: 561 |
Plastic surgeons do nipples - but if you need new bearings....
New joints for old!
Just a quick update. Vaseline was recommended for the bonnet tapes - now applied and the creak has gone........
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
i have a creaking sound from dash area too. When i put some downward pressure on the steering wheel it stops - so i think its the wheel column/dash making contact.I will have to look at the clearance under there.
