Topics49,849
Posts837,410
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
I'm not sure about the battery disconnection idea, as SpannerJuggler pointed out on another thread, for quite a few years now ECUs have stored their fault codes on EEPROMs (like Flash Memory) which don't require a poser supply to preserve their contents.
Plugging in a code reader to find out what the problem is is the only real option, but as the car's under warranty, then this is probably best done by the dealer.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Depends on the ECU as to how it behaves on a battery off.
As for the codes if you have a hard fault it'll be back.
Could be a multitude of causes.
If under warranty why drive in this condition just ask your dealer to collect it, if you conked out in a dangerous place you'd regret it.
