10 members (Graham, G4FUJ, John V6, RJW, AZJowett, RedThree, Alistair, JMcL, Orjan, Scrambledsignals, Luddite), 97 guests, and 44 robots.
+8Rich 100
John V6 66
Luddite 56
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
Factory meet
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,937
Posts838,576
greenteagod
Page 19 of 40 1 2 17 18 19 20 21 39 40
Originally Posted By Clock
I got the bezel for the MIG chromed
Just a word of warning if you are going to modify a MIG clock's bezel then be aware of the precautions you need to take for working with radioactive materials, it's low risk but even so!!!
I wondered why my hair started falling out!
I stripped the paint off the bezel (I'm assuming your other reference to bezel is the clock face?) and polished it with a Dremel. I'm not sure what material they use but it has stayed highly polished for well over a year!
Oh now you tell me.. I've just got a MIG clock, its certainly a loud tick! none shall sleep! I guess at Mach 1 in a MIG the clock ticking is the last thing to worry about but on my desk in my study is quite another matter.. if I find the whole of the upstairs of the house glowing at night i'll know why!!
2008 4/4 1.8 Duratec
Black Rat
Black Rat
How long do they run for on one winding cuckoo and is there space behind the dash on the right hand side of a 2013 ? Or would it need a mounting bracket ?
Keith
2013 narrow bodied + 4 Ruby.
That is a masterpiece ~ perfection in fact. i don't think I've seen a better one.
Roger
Drive on the Wild Side
I must say very nicely executed, it's a quite involved fitting a new dash and rewiring instruments and switches, congratulations. thumbs
Adrian
Originally Posted By PaulJ
I am so envious, well done on all the work it entailed, the finished job has to have been worth it - I now want improve my dash.
+1
For anyone that's interested I have attached a write up of how I modified a MIG clock. Probably a few typos etc in it but may be of interest.
I will also do a write up on making an air temp gauge and post later.
No wonder your TM name is Clock
Top, top work
I run my central heating on the radioactive output of my MiG clocks! I'm greedy, I've got a couple!
Keith......I think it's meant to be a 5 day movement.....mine certainly runs for 3 to 4 days. And accurate as well. As far as mounting is concerned, there should be space on the r/h side of the dash....you just need to be aware of where the ash frame is. There are two types of MiG clocks.....one with a single stopwatch internal dial, which has a body half the depth of the other version which has two internal dials, a stopwatch and a flight time recorder. The first clock, which I have on my Roadster in that position is less critical depth wise. I can measure both mine and let you have the dimensions if you need them.
PS.....I meant to add. I'm a great fan of these clocks, they do suit Morgans and I've lost count of the number of people who see it in my car and ask about them.
The only issue with them is that they are not illuminated electrically. They have relied on the luminous dials which on mine have now worn out....thankfully as I don't trust Russian safety standards! I fitted a little stainless pillar cockpit led light to the dash to one side of the clock to illuminate the face....from Holdens. It works quite well and has a classic look.
You can just see it by the upper right of the clock in the photo.
