10 members (PaulyG, hugo, Heinz, +8Rich, RichardV6, BillHart, mph, sbarracl, Adam12, TBM),
433
44
New
Topics48,365
Posts813,387
Members9,215
Posts: 2,361 |
If you would like to keep up to date on the series, please click here. http://www.morganchallenge.co.uk
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 2,361 |
Posts: 3,514 Likes: 8
Posts: 3,514 Likes: 8 |
That industrial unit looks remarkably like another I know in Cheltenham Lawrie. Did they do their magic?
I can never make up my mind where to finish my screw heads, on circular items, mostly I leave them making a line around the circle, but on other things sometime vertical and but rarely horizontal - just me.
Posts: 2,361 |
I can never make up my mind where to finish my screw heads, on circular items, mostly I leave them making a line around the circle, but on other things sometime vertical and but rarely horizontal - just me. Oh the magic has been done, will find out properly on Thursdays test at Castle Combe. But on the road by god does she go
Posts: 2,361 |
Update time       And of course we need.......   Here you can see the difference between a brand new tyre and one that's done roughly 2hrs total usage  Notice from hard cornering the tyre has done its job perfectly and the heat (blue) is on the outter edges. When the tyre has cooled the blue areas become a lot harder, which is then loss of grip. Also you can see the amount of tread worn away by looking at the difference in tread depth. The tyre is peeling off, again from heavy use, again this rubber cools quicker then the tyre itself, when this happens the tyre peel sinks into the softer rubber. If Henry was to use this tyre again under hard conditions he would have a lot less grip as parts of the tyre would warm up quicker then other areas.
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
The bonnet mod could work well for some in hotter climates...
Richard 1976 4/4 4 Seater
Posts: 2,361 |
The bonnet mod could work well for some in hotter climates... We done the same on our V8 Class B car, it works very well
Posts: 5,111 Likes: 56
Black Rat Charter Member
Posts: 5,111 Likes: 56 |
The bonnet mod could work well for some in hotter climates... We done the same on our V8 Class B car, it works very well Should keep the ice of the screen
Posts: 2,361 |
The bonnet mod could work well for some in hotter climates... We done the same on our V8 Class B car, it works very well Should keep the ice of the screen I dont get it sorry! Sleepy brain tonight
