3 members (How, Mike D, sprinty), 350 guests, and 30 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
Page 6 of 8 1 2 3 4 5 6 7 8
Black Rat
Black Rat
Some of us actually bought a Morgan because we wanted a "classic" car that was reliable but still drove like a "period" car.
Keith
2013 narrow bodied + 4 Ruby.
Yes, me too. I bought a Morgan because I wanted a car with 'period' characteristics. If I had wanted a car that handled like modern sports car I would have bought a Lotus. But I think it's good that such developments are available for those people who want them.
PJB Offline
HJP, thanks for your initial view of the 5L. I had nothing to do with the suspension design on the M3W except test driving various suspension configurations and writing the setup instructions. I am sorry if you and others found the rear suspension difficult/impossible to set up. I do know it is not easy. I know you will know a lot of what follows, but others might be interested, possibly.............
There are internal rebound springs in both the front and rear dampers (Made by B.A.D.), trouble is that you can't see if these rebound springs are in contact or not at ride height, like you can on the front of the Traditional 4 wheeler. It is essential to set the rear ride height accurately to get the rebound springs just free. Of course if the rebound springs are compressed the initial rear ride is HARD, and too much clearance at too low a ride height and the rebound spring comes in suddenly on rebound as the rear goes light. I think that the rear system would have been more consistent without the rear suspension rebound springs considering the large load change from one person to two etc. So I appreciate your disappointment, but it was a SUPLEX design that was passed off by Morgan....
A bit of history. The development Morgan M3W cars used coil overs with SUPLEX springs and B.A.D monotube dampers and internal rebound springs. There were also long 'spring assists' (like long bump stops but more durable) on the front damper rods to give significant rising spring rate. Hence the front suspension movement in bump was limited and the suspension movement in rebound was also limited by the rebound springs, THUS the bump steer problems that occurred later with the SPAX units did not occur as the original cars' suspension travel was less. I drove an early demo car with SUPLEX/BAD units on, loved it.
Morgan approved these SUPLEX /BAD units for production. Then when the production volumes built up and were approx. doubled Morgan went to SPAX instead with twin tube dampers and no rebound springs. The dealers' demo cars also had the SUPLEX/BAD units on, so many customers bought cars with SPAX units where they had driven demo cars with SUPLEX/BAD units, I do not know if the customers were told there was a specification change for production, but I would have thought so.
Morgan fitted SUPLEX/BAD units to the M3W instead of SPAX when they drove to the North Cape of Norway because of their superior ride and handling.
When SUPLEX/BAD reintroduced their original units as aftermarket, I was then invited by Morgan to test drive their test car with them fitted. My report to Morgan matched what their test drivers thought, which was a relief! I believed they felt as good as the original SUPLEX/BAD units on the first demo cars and compared with the production SPAX units had less roll, less steering kickback, better road surface isolation and better steering response.
I try to be careful on TalkMorgan, as although I am not an employee of SUPLEX, being an independent automotive consultant, I am naturally viewed as a supplier by TalkMorgan and Morgan Motor Company.
I hope that this blurb has helped a little and given some background. Regards Peter. PJB.
PJB Offline
Simon, thanks for the background, much appreciated - good to see you keeping MulFab going since you kindly showed me around MulFab a few years ago. A little clarification maybe.
The SUPLEX 5L rear suspension system was designed by me from scratch independent of SUPLEX, prompted by an approach from a very enthusiastic Morgan owner, though I was not taken on for that project. It has developed into the SUPLEX 5L project with help from Dan White & others.
The RS developed from the front suspension development I was also doing previously until Dan & I got together and realised were had been working independently on the same thoughts, then the RS was released and sells well.
All the best to you Simon and Peter - cheers Peter PJB.
Spot on. And probably for a lot less money!
Ray Offline
Originally Posted By Peter J
Originally Posted By SimonH
The rear suspension was advertised 5 odd years ago, in conjunction with the Librands wishbone kit. I designed the wishbone kit, or at least made it work form the original designs...although Ive improved it since it was first advertised
We had no interest at the time although we had a working driveable prototype, and so it was put on the backburner.
Am I right in thinking that Williams sold you extensively modified car a few years ago, including the multi link rear suspension?
Yes Peter, the car was for sale at Williams last year. Toyed with the idea of buying it, but the deal did not work out for me. Test drove the car, nice drive. A lot different from a normal trad.
Black Rat
Black Rat
Originally Posted By Mike Hughes
You mean a fuel injected, disc braked, wide wheeled, radial tyred, five speed (all-synchro) period car of course ? wink
Some of these things are inflicted upon us by EU Regs. But a Morgan is still the nearest modern car to a classic driver you can get. I have the tall narrow tyres and was referring to the handling characteristics drive
Keith
Peter, it was last year I considered it when buying my Roadster in May.
Two things put me off:-
1. it was a category D crash car
2. the price was high & Williams offered me £3k less than Allon Whites did for a cheaper lower mileage standard Roadster.
From memory after I spent my wad Williams dropped the price £5k , a level at which I would have been interested.
Thanks PJB very interesting background on the M3W suspension.
Neil
Any more news on the suplex 5 link rear suspension as to when it will be available to retrofit to a trad ?
