5 members (TBM, Paul F, Cerberas, Franky, Brummie Steve), 184 guests, and 81 robots.
Sagging Hood
Topics49,858
Posts837,464
Page 1 of 5 1 2 3 4 5
#300799 28/08/15 05:05 PM
Matty Offline OP
Just got home
Filled with fuel to brim?
20 miles later fuel pump fails. Engine light on
Called Morgan recovery
Two hour wait?
Remembered old trick from morris minor days
Sharp tap on electric fuel pump can do the trick
Bloomin ell it works.
Engine light on and pump groaning a bit.
Got me home
Pump groaning.
This is terminal me thinks
Any advice please
18k on the clock
I will be expecting Morgan to pay a large part of this but dont hold out much hope
Matty #300805 28/08/15 05:21 PM
Hope hope hope
Matty #300840 28/08/15 06:47 PM
Matty Offline OP
I am a moron. I was hitting the fuel filter
Matty #300848 28/08/15 07:00 PM
laugh2 I was wondering how you hit something inside the fuel tank! I hope you find a permanent fix soon smile
Andy
Matty #300863 28/08/15 07:23 PM
I had some concern engine running early August I decided to change the fuel filter, I'll buy it from a shop that bmw 100m from my workplace 90.50 euros with 25% discount, it is expensive because the fuel pressure regulator (3.5 bar) is integrated in the fuel filter sets I do not regret the change because after shaking his flowed like black ink, the filter had just over two years and more than 30.000km, bmw recommended change every two years on the X5 3.0i-4.4i-4.6i-4.8i and mounted also on land rover range rover 4.4i.
Since I bought for future mounting external Walbro fuel pump and Bosch fuel filter screwed connector-type and adjustable external regulator for the fuel pressure.
Matty #300872 28/08/15 07:33 PM
Same symptoms as when my pump quit. Made a groaning noise on restart, engine check lite came on, reduced fuel pressure at the rail. A new pump cured all.
Matty #300892 28/08/15 08:00 PM
Matty Offline OP
Cheers guys
Matty #300907 28/08/15 08:26 PM
HJP Offline
Matty , I had the same problem , I banged various bits and it started , when it happened a second time Krazy Horse tracked it down to a poor earth to the pump .
Hugh
Matty #300919 28/08/15 09:23 PM
I wonder why fuel pumps are failing
I like probably everyone else on this forum runs at least 1 daily driver with fuel injection and I have never known a fuel pump to fail, ever. Even with high miilages over tens of years.
So To sum up,
I now have to expect the crank pulley bolt to exit through the front cover thereby increasing the ventilation for the now non existent cam belt.
And fuel pump to withdraw its labour with little or no warning.
Thank goodness I have the HD rectifier.
Just what I need with 1500 miles ahead of me next week in Switzerland.
GLLOQ #300940 29/08/15 05:20 AM
Hello give us the référence for buying it .thanks
