0 members (),
291
84
Topics49,847
Posts837,389
Posts: 797 |
Just got home Filled with fuel to brim? 20 miles later fuel pump fails. Engine light on Called Morgan recovery Two hour wait? Remembered old trick from morris minor days Sharp tap on electric fuel pump can do the trick Bloomin ell it works. Engine light on and pump groaning a bit. Got me home Pump groaning. This is terminal me thinks Any advice please 18k on the clock I will be expecting Morgan to pay a large part of this but dont hold out much hope
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Posts: 797 |
I am a moron. I was hitting the fuel filter
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
 I was wondering how you hit something inside the fuel tank! I hope you find a permanent fix soon
Andy
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
I had some concern engine running early August I decided to change the fuel filter, I'll buy it from a shop that bmw 100m from my workplace 90.50 euros with 25% discount, it is expensive because the fuel pressure regulator (3.5 bar) is integrated in the fuel filter sets I do not regret the change because after shaking his flowed like black ink, the filter had just over two years and more than 30.000km, bmw recommended change every two years on the X5 3.0i-4.4i-4.6i-4.8i and mounted also on land rover range rover 4.4i. Since I bought for future mounting external Walbro fuel pump and Bosch fuel filter screwed connector-type and adjustable external regulator for the fuel pressure.
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
Same symptoms as when my pump quit. Made a groaning noise on restart, engine check lite came on, reduced fuel pressure at the rail. A new pump cured all.
Posts: 797 |
Posts: 1,213 |
Matty , I had the same problem , I banged various bits and it started , when it happened a second time Krazy Horse tracked it down to a poor earth to the pump .
Hugh
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I wonder why fuel pumps are failing
I like probably everyone else on this forum runs at least 1 daily driver with fuel injection and I have never known a fuel pump to fail, ever. Even with high miilages over tens of years.
So To sum up,
I now have to expect the crank pulley bolt to exit through the front cover thereby increasing the ventilation for the now non existent cam belt.
And fuel pump to withdraw its labour with little or no warning.
Thank goodness I have the HD rectifier.
Just what I need with 1500 miles ahead of me next week in Switzerland.
I had some concern engine running early August I decided to change the fuel filter, I'll buy it from a shop that bmw 100m from my workplace 90.50 euros with 25% discount, it is expensive because the fuel pressure regulator (3.5 bar) is integrated in the fuel filter sets I do not regret the change because after shaking his flowed like black ink, the filter had just over two years and more than 30.000km, bmw recommended change every two years on the X5 3.0i-4.4i-4.6i-4.8i and mounted also on land rover range rover 4.4i. Since I bought for future mounting external Walbro fuel pump and Bosch fuel filter screwed connector-type and adjustable external regulator for the fuel pressure. Hello give us the référence for buying it .thanks
