Topics49,868
Posts837,636
Posts: 1,461 |
I drove back from Toulouse on Friday in blazing heat. I should have put the hood up - I now have burned wrists.
Today, having raised the tyre pressures to 1.9 bar (about 27.5psi) I went for a drive on my standard mountain route, which takes about an hour and a quarter.
The tyre pressure change worked very well. On the factory-recommended settings, the car was fine on the autoroute but felt sluggish and indecisive on B-roads.
It is amazing how much one can do (to make things better or worse) just by fiddling with tyre pressures. I think the Contis are OK but I look forward to wearing them out and replacing them with Vredesteins. I am not sure that there will be much difference in grip except on wet roads (which is not generally my problem) but I think there should be more feel.
I enjoyed the drive today. The car was fun, easier on that demanding route than the M3W had been, but of course quite a lot more difficult than a modern car like my Honda Civic.
So far I think there is a good chance that I have got exactly what I was looking for - a sort of vintage driving experience combined with modern reliability.
The only negative points are things I already knew about. It is impossible to do "heel-and-toe" gearchanges; the pedals on the M3W are far superior in this respect. There is nowhere to rest the clutch foot comfortably, but in this the 4/4 is better than the M3W. The steering is rather weird, especially in tight turns at low speeds, though overall the handling is surprisingly good - far better than the Morgans I drove 30 or 40 years ago.
Oh, and I keep looking for the RECIRC button when I find myself behind a smoky diesel.
By the way, who needs doors? With sidescreens removed, I find it is easier to get in and out without using them, as in a single-seater racing car or the M3W.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Continue to have fun but be wary of putting so much air in the Contis especially if it rains. I would have thought 22-24 is a good compromise.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Keep smiling and enjoying.
Richard 1976 4/4 4 Seater
Posts: 14,009 |
All you need to do now Peter, is strip off that windscreen and fit a pair of aero screens!
Posts: 3,562 Likes: 12
Posts: 3,562 Likes: 12 |
"I now have burned wrists."
I seem to recall you had the same problem when you picked up the Three Wheeler didn't you Peter?
I had the same problem trying to heel and toe with my Plus 4 and found the brake pedal too low when depressed, so as a temporary solution I screwed a larger pedal cover on the accelerator, so that I can at least get the edge of my foot on it, but I need to raise the pressure point on the brake or lower the accelerator somehow.
Nice first impressions, I wonder how long you will be able to hold off on some upgrades?
Posts: 1,461 |
Re the wrists, yes, I should have learned from last year. The journey started off pleasantly overcast, ideal top-down driving conditions and around Montpellier (almost halfway) there was even some light rain. Then I was a bit late in responding when the sun came out and did not realize until too late that I was being grilled to a crisp.
For my drive this morning, with the temperature in the high 20s Celsius, I wore a lightweight long-sleeved polo neck and gloves and a cap. It was hot but I was not burned.
Which upgrades do you suggest, Paul?
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
To each their own of course, and you have different tyres to mine, but you might find 1.7 bar gives you a better compromise between feel and ride. 1.9 bar would, I think, give a fairly harsh ride.
I agree that the car does feel squirmy with the factory recommended 1.5 bar.
Regarding steering: if it feels a bit weird you may need to get toe-in and camber checked. There are several opinions on what this should be on a 4 wheeled Morgan. I have had two knowledgeable people suggest 0º toe-in, and one suggest 0º camber and the other 1º camber.
Posts: 149 |
Glad you're enjoying the new 4/4. 22 psi works well for me and I'd recommend the addition of brake reaction bars as an inexpensive way of 'firming up' the front end. Wait 'til the engine frees up a bit too and you can make more enjoyable progress.
Norfolk Phil 2014 Sport Blue 4/4 1959 Frogeye Sprite
Posts: 1,461 |
I have the brake reaction bars and Suplex front-end kit, also the Panhard rod.
