9 members (CooperMan, Neville1, Cerberas, Pittsartist, JMcL, RichardV6, Craig Jezz, MartinB60, GrumpyPa), 321 guests, and 128 robots.
+8Rich 75
Topics49,869
Posts837,659
Moggo
Page 1 of 4 1 2 3 4
P Dron Offline OP
I drove back from Toulouse on Friday in blazing heat. I should have put the hood up - I now have burned wrists.
Today, having raised the tyre pressures to 1.9 bar (about 27.5psi) I went for a drive on my standard mountain route, which takes about an hour and a quarter.
The tyre pressure change worked very well. On the factory-recommended settings, the car was fine on the autoroute but felt sluggish and indecisive on B-roads.
It is amazing how much one can do (to make things better or worse) just by fiddling with tyre pressures. I think the Contis are OK but I look forward to wearing them out and replacing them with Vredesteins. I am not sure that there will be much difference in grip except on wet roads (which is not generally my problem) but I think there should be more feel.
I enjoyed the drive today. The car was fun, easier on that demanding route than the M3W had been, but of course quite a lot more difficult than a modern car like my Honda Civic.
So far I think there is a good chance that I have got exactly what I was looking for - a sort of vintage driving experience combined with modern reliability.
The only negative points are things I already knew about. It is impossible to do "heel-and-toe" gearchanges; the pedals on the M3W are far superior in this respect. There is nowhere to rest the clutch foot comfortably, but in this the 4/4 is better than the M3W. The steering is rather weird, especially in tight turns at low speeds, though overall the handling is surprisingly good - far better than the Morgans I drove 30 or 40 years ago.
Oh, and I keep looking for the RECIRC button when I find myself behind a smoky diesel.
By the way, who needs doors? With sidescreens removed, I find it is easier to get in and out without using them, as in a single-seater racing car or the M3W.
Glad you are having fun
Black Rat
Black Rat
Continue to have fun but be wary of putting so much air in the Contis especially if it rains. I would have thought 22-24 is a good compromise.
Keith
2013 narrow bodied + 4 Ruby.
Keep smiling and enjoying.
All you need to do now Peter, is strip off that windscreen and fit a pair of aero screens!
"I now have burned wrists."
I seem to recall you had the same problem when you picked up the Three Wheeler didn't you Peter?
I had the same problem trying to heel and toe with my Plus 4 and found the brake pedal too low when depressed, so as a temporary solution I screwed a larger pedal cover on the accelerator, so that I can at least get the edge of my foot on it, but I need to raise the pressure point on the brake or lower the accelerator somehow.
Nice first impressions, I wonder how long you will be able to hold off on some upgrades?
P Dron Offline OP
Re the wrists, yes, I should have learned from last year. The journey started off pleasantly overcast, ideal top-down driving conditions and around Montpellier (almost halfway) there was even some light rain. Then I was a bit late in responding when the sun came out and did not realize until too late that I was being grilled to a crisp.
For my drive this morning, with the temperature in the high 20s Celsius, I wore a lightweight long-sleeved polo neck and gloves and a cap. It was hot but I was not burned.
Which upgrades do you suggest, Paul?
To each their own of course, and you have different tyres to mine, but you might find 1.7 bar gives you a better compromise between feel and ride. 1.9 bar would, I think, give a fairly harsh ride.
I agree that the car does feel squirmy with the factory recommended 1.5 bar.
Regarding steering: if it feels a bit weird you may need to get toe-in and camber checked. There are several opinions on what this should be on a 4 wheeled Morgan. I have had two knowledgeable people suggest 0º toe-in, and one suggest 0º camber and the other 1º camber.
Glad you're enjoying the new 4/4. 22 psi works well for me and I'd recommend the addition of brake reaction bars as an inexpensive way of 'firming up' the front end. Wait 'til the engine frees up a bit too and you can make more enjoyable progress.
Norfolk Phil
2014 Sport Blue 4/4
1959 Frogeye Sprite
P Dron Offline OP
I have the brake reaction bars and Suplex front-end kit, also the Panhard rod.
Page 1 of 4 1 2 3 4
