3 members (Chris Cosher, TBM, RichardV6), 310 guests, and 105 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,627
Moggo
Page 3 of 4 1 2 3 4
P Dron #301054 29/08/15 04:31 PM
It's also worth mentioning that early easy ups had a fragile rear frame which in an odd case broke, so press down both sides with equal & careful pressure. With the hood cover in place I don't secure the catches. The hood sits OK under it own weight with only an occasional knock on a rough road.
DaveW #301140 29/08/15 10:42 PM
Yes. I too normally leave the rear unclipped with either the tonneau cover or the hood cover.
P Dron #301150 30/08/15 05:45 AM
Agree about the release handle being rather stiff but suppose it does have quite a job in releasing the pins , think I will try getting some grease into the pins to make them more inclined to pop open !
As has been said TM is an excellent forum due to the help from many experts here !
Definitely much better now and have used grease sparingly as Peter said or it will get onto hood etc .
P Dron #301237 30/08/15 12:24 PM
With excess grease on the pins it is a certainty that you will get grease on the back of your shirt as you reach in for the umbrella.
2004 Silver Roadster S1
Rev 4K #301267 30/08/15 02:33 PM
We have two nice folding/telescopic handle type umbrellas, in a colour to match the hood,that fit nicely under the side of the passenger seat nearest the door.
P Dron #301273 30/08/15 02:56 PM
I have a Morgan one.
Blackadder #301599 31/08/15 07:07 PM
Originally Posted By Blackadder
These handles are stiff - I felt worried I might break mine when using it but I was being over cautious. Have you tried giving a stronger pull on the lever - it's tougher than you would think and it has to be forced past the resistance to undo it.
From personal experience, I can testify that the handle can break...
Cheers,
BertR
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
BertR #301603 31/08/15 07:15 PM
Cheers,
BertR
Yes, as pointed out earlier, the lever arm of the release mechanism is too short. After Trond Bråthen installed his revised release mechanism on my car, a gentle pull is enough to release the hood.
Harald
Harald
P Dron #301605 31/08/15 07:18 PM
P Dron Offline OP
There are more durable handles on the market which would probably not change the unit cost significantly. Perhaps, in the continuing search for 4/4 perfection, the MMC might consider this as a priority, some time before the centenary in 2036.
Soleng #301616 31/08/15 07:36 PM
P Dron Offline OP
Cheers,
BertR
Harald
Not this Trond Bråthen, I suppose? He does seem to have been into heavy metal, however...
https://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CCIQFjAAahUKEwjfzM2FiNTHAhXIvBQKHfOXAQc&url=https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FTrond_Br%25C3%25A5then&ei=8qvkVd-LGMj5UvOvhjg&usg=AFQjCNGSAQ_vqySWxHSf3_phdbPCfVoX-g&sig2=FsU-UxrxD9RipuFmom6Y-w
Page 3 of 4 1 2 3 4
