1 members (Socalm3w),
360
35
Topics49,897
Posts838,017
Posts: 234 |
POOR OLD Mr. Mog has developed a Tch Tch sound at the rlright rear of car it is a 99 4/4 Low line 4 seater.
Problem could be a broken pull off spring or a hub bearing perhaps, any insights?
Just now in sw France near Bayonne
Cannot get any assistance in local garages to inspect any ideas?
Thanks Chris444 and Mr. M o g
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
I guess you looked for a stone in the tyre? Is the exhaust rubbing? Is it speed related?
Posts: 306 |
I agree, Check for a stone or nail ect in the tyre tread. David
1997 Plus 4, Metalic Blue. 2000 Toyota Yaris. (The Tardis)
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
If it has wire wheels, check for a broken or loose spoke.
Posts: 367 Likes: 1
Posts: 367 Likes: 1 |
I had a similar noise from the rear of my roadster travelling down through France last year. (maybe it's France) anyway turned out the holding screws for the brake drum had backed off and the drum was loose. Wheel off to find the problem, tighten screws. Job done. Advice to service company to use locking compound next time. Hope this helps
Andy
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
There are many possible causes of noises coming from the area of the rear wheel, some are mentioned above , and no doubt you will get many more , because without more data it is a mite difficult to diagnose.
If you have wire wheels , make sure the securing nut is REALLY tight. of not the wheel can fret on the threads. Is is possible (but unlikely without some poor maintenance) that the woodruff key in the half shaft can wear and allow some movement between the hub and the shaft. There could be a wheel cylinder sticking on , which is allowing the shoe to rub slightly on the drum. Is the handbrake releasing fully, if not the same symptoms as above. Has the rear spring run "dry" and needs some chain lube between the leaves. Are the axle U bolts tight? If not the axle can move very slightly. Are the rear shock absorber bolts too tight and not allowing the rubber bushes to flex.
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
As andy says, check the brake drum screws/nuts, happened to me, both drums loose after servicing.
1993 T16 +4 Lancia Blue.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Hi Chris
Hope you get it sorted
Just out of interest, you describe Mr Mog as a 'low line' 1999 4 seater. Interested as to what that means
Mine's a 2000 4 seater
Posts: 381 |
If you have the opportunity to go to Toulouse, there is a Morgan dealer: Marcassus http://www.marcassus-sport.com/tél 05.62.19.29.00. Chris Atton is an English man. and also other garages which can have a look to your problem : "Classic cars & youngtimers" 8 route de Bayonne Toulouse. tél 05.61.44.91.49 Nostalgic British Cars 14 chemin de Fondeyre 31200 Toulouse tél 05.62.20.28.73 But if you find a small traditional garage, they can have a look, a Morgan is not complex. I live close to Toulouse and you can contact me.
Regards 2005 PLUS 4
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
Took mine out yesterday and heard a tinkling sound from the front end. Stopped at the side of the road and looked underneath and saw a set of long-nose pliers sitting in the towing hook! Slightly worrying as she had just been serviced and who knows what journey down the engine they made before lodging where I found them.
