Topics49,867
Posts837,614
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
The coating on the windscreen pillar brackets on my 2008 +4 began to bubble & flake. I was speaking to another owner on Wednesday who has the same problem - same model, same year - in fact our cars were built at around the same time.We did wonder whether there was a duff batch in that period. Does anyone else have a similar problem and maybe a solution? I was thinking of removing the remaining coating and polishing the brackets, or possibly having them powder-coated. Any thoughts out there?
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Posts: 3,825 Likes: 69
Posts: 3,825 Likes: 69 |
My 2005 roadstr suffered in the same way. I stripped it all off and polished. Nick
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
The powder coating MMC uses isn't robust enough to survice the Easy-up hood clips. Once it has started to chip at the top it seems then to come away, perhaps water gets in.
With the 2009 Roadster I did look at buying a new set, getting them stripped and then hard anodised, but the sale solved the problem, BUT the 2014 Plus 9 is starting to show it will go along the same route. So perhaps I'll re-visit the idea.
Actually cast stainless would be far better...but VERY expensive as a 1 off.
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Actually cast stainless would be far better...but VERY expensive as a 1 off. If enough people expressed interest it would bring down the unit cost. I would certainly be keen.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Actually cast stainless would be far better...but VERY expensive as a 1 off. peter where did you put the extra cylinder.
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
There has been more than one finish to the A pillars (probably). The most common is the flat "satin" grey colour. But my 05 Roadster has a darker grey lacquer which has been sprayed on. This may have been done post factory of course, but it's shiny and hasn't budged so far. Phil Ledgerwood sold chromed posts in 2008 for a while, but found that the chrome didn't take well so stopped doing them.
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Yes there is a solution a lad in Normog had the same problem he spotted mine in the garage last year and asked the chap could he do anything . I have seen his car in a barn ( farmer ) he is called Dave Smith and it is sprayed to match his light pods . The garage that did it is in Darlington so its a long drive for you. You can phone the sec for Normog and get Daves number. Then ask him for an e-mail photo.
Posts: 347 |
I noticed that my windscreen pillars on a 2014 car have chipped where the easy-up hood attaches. From PeterJ's comments I will now apply some resin touch up to hopefully reduce the spread of the problem.
2014 +4, Le Mans Blue / Magnolia "Meg" the Mog
Posts: 651 Likes: 12
Posts: 651 Likes: 12 |
Heart of England Morgan sells stainless brackets for older morgans. With sufficient interest they may want to provide brackets for the current cars. Harald
Harald +4 4-seater 2008 Squadron Blue
There would be a good profit for them if they made some stainless ones.
