Morgan Aero 8
5 members (Pittsartist, deano, Mike D, Ruut Bianchi, JohnHarris), 285 guests, and 33 robots.
+8Rich 102
John V6 59
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,913
Posts838,168
Georgetoad, woolfie
le Asbo du Bling
le Asbo du Bling
Originally Posted By Jappo
I'm about to go and sit in the garage so we can share a pint together now, don't know where my wife is smile
Jappo,
Welcome you have now officially join the Aero clubparty
A word to the wise, be careful what you buy it for Christmas as the other half will be looking scared
Slowly going green
Mr Fezza
Mr Fezza
Another question chaps:
Speedo accuracy - according to my TomTom when the speedo indicates 100mph it is actually doing 87mph. Is it possible to recalibrate the speedo?
Thanks again!
Not sure if you can re-calibrate. My S1 was always around 10% out.
check the tyres you're running on - could be that they are lower profile than the original rubber and putting the speedo out? (or is that just an old wifes tale?)
Maxxed out!
or recalibrate your tom tom hide
at least you can tell your mates that your morgan does over 200mph englandwave
dmat
le Asbo du Bling
le Asbo du Bling
dmat
dmat,
You must still have your foot on the brake hide
Slowly going green
Jappo Offline OP
Jappo,
Right, I have officially joined the Aero Club - so, where are the gigs, where are we all going to meet up, what should be blanked off as Morgan dates in my diary? I know the big one is at Prescott the weekend of the 25th July but there is also the Silverstone Classic that weekend. Anyone Morgan going to Silverstone?
U
TM Photographer of 2008
U
Thanks again!
If the speedo is similar in design to those fitted to a Plus 4 it can be easily done. On the Plus 4 the digital display of total miles is toggled to trip miles by pressing a button on the speedometer. If you hold this button down while switching on the ignition the display will show a five digit number which calibrates the speedo. One of the digits will be flashing indicating that it is possible to change it. As far as I recall, changing the numbers to the right hand side of the display (tens and units) fine tunes the calibration. Pressing the button changes the flashing number whilst (I think) a continuous press moves to the next number.
I found this out by chance and ended up with the speedo reading 120mph when I was actually doing 30mph. I would advise you make a note of the original number so you can put it back to where it was. I didn't so had a fair bit of trial and error to sort it out. Again, if I remember correctly, switching off the ignition stores the changes to the number.
Presumably, when calibrating the speedo to the gps it should be done on a flat road.
Ken
