5 members (Dougie, DCH, riri, Montegue, +8Rich), 300 guests, and 34 robots.
+8Rich 93
John V6 49
Posts837,988
#303127 07/09/15 04:21 PM
I'm the new owner of a '69 Plus 8 with a broken rocker switch on the dash. The problem is, I can't figure out what it's supposed to do. It's at the right end of the lower row and has a white triangle pointing up and a red triangle pointing down. Can anyone solve the mystery for me? Thanks v. much
Tom Morris
1972 Plus 8
1932 Super Sport "Beetleback"
1961 Morris Minor Tourer
1972 Triumph T120V
I had some mysteries on my 71 Plus 8, which I sold a couple of years ago. This is what I had.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Have you switched it on to see what activates?
If nothing then the above diagram could apply?
Check rear foglight ( if fitted) for on/off, but the arrows you have are not the modern rear fog signage....
I think that's meant to be an engine cut-out switch.
1972 4/4 2 Seater
It is an engine cut out switch. It also operates as a parking switch; that is if the parking lights are switched on, the passenger side lights should be switched off leaving the driver side parking lights switched on.
Parking lights are the rear tail light and the side light mounted on top of the wing.
These swiches over time can stop working (as against) fail as lack of use and time allows the contact grease (petoleum jelly) to solidify. They are repairable althoug the sidelight / headlight ones do have a tendency to burn out.
PM me if you need more help or even a spare.
Brilliant! You lot are just so d****d useful. Thank you.
Tom Morris
1972 Plus 8
1972 Triumph T120V
Watch your language; it could be mistaken for a compliment!
Surely one of the switches activates the passenger ejector seat!
I have an interesting button in my Honda. I have not yet used it.
Do you have a sunroof that flips open?
Roger
