6 members (Luddite, Soleng, High Hamster, mickyb, asbojohn, Image), 391 guests, and 19 robots.
+8Rich 92
Posts837,284
Originally Posted By plug
sorry also I meant to say that the auto electrician suggested adding a relay to cut the current going to the switch as he wondered if the dim dip unit had a unit in it to reduce current to the switch.
I was about to say also add a relay.
Definitely add a relay! The switch just can't handle the current otherwise.
I had exactly the same problem on my '91 4/4 after the Dim Dip was removed.
