7 members (DJC, andymog1, John V6, Simon, TalkMorgan, IcePack, Stephen888), 272 guests, and 28 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,116
#303584 09/09/15 11:29 AM
has anybody had a problem with main 50 amp fuse blowing on a 4 4 mine is a 2002 and it has blown twice
once in rain with everything on but no water ingress that could be seen.
and once in bone dry conditions with only head lights and heater blower on 1.
no other fuse had blown, once main is replaced all is perfect instantly.
noted that the 3 x bosch relays were quite hot too much to touch comfortably.
ANY IDEAS?
MORGAN 4/4 1800
MERC E CLASS
TRIUMPH TROPHY SE 1215
TRIUMPH SPEED TRIPLE SE 1050
HONDA CRFX
BSA C12
No real ideas but when I bought a new +8 in 2002 the dealer gave me a spare main fuse and said there had been quite some incidents of them blowing so best carry a spare, mine never did and not heard much about it since. To pop a fuse of that rating would require a serious grounding of feed or just maybe a faulty fuse, however if that were the case it would have blown long before now. I would be inclined to bridge the fuse holder with lower rated fuse wire, turn on the ignition and then move and squeeze the harness wherever you can get hold of it especially on sharp bends over corners like the bulkhead under the bonnet as that was a well known rub point some time ago and see if you can get the lower rated fuse wire to blow. Good luck and sorry that's all I can think of.
BR Colin
