10 members (Grumpy2, Image, JMcL, aerotaff, John Wilcox, SteveT, DJC, petemog, Snowden, uvk33n), 128 guests, and 14 robots.
+8Rich 103
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,509
AlexCreasey
DaveW Offline OP
My garage doors face South, and this means that sunny afternoons cause them to behave like giant radiators, and the inside temp can exceed 30 degrees. A few years ago I decided to try some thin tongue & grooving board, which I stuck on one door with 'no more nails'. The problem with this was that I had underestimated the added weight, which made lifting the up & over door a real chore. I also had to prop it open because there was a risk of it coming down on a car. So I didn't do the other door, and used the wood up recently to build a vegetable box, which has won me loads of favours from MrsW............
It dawned on me that closed cell neoprene would be a much better bet, much lighter than wood, so recently I have stripped the wood and applied some neoprene. I used 'camping mat' from Blacks (the outdoor shop), which at present is supplied yellow on one side and blue on the other, although it was previously available in red and black. There's an offer at present which means the second one is half price.
I think I bought about eight...........
I've used no more nails to fix it after roughing up the blue side with a pointed stick.
And this is how it looks.......... laugh2
Y
Y
Excellent idea ,well done job.
Frank 4x4 will like that colour on the door! wink
Cheers,
Hi,
I have the same south facing problem and I'm half way through putting some foil sided bubblewrap type insulation on with no-nails. It is very light and I just hope it does the job.
Regards
Mark
Good idea...
Do you reckon I'd get a grant from my local council!
Keith
DaveW Offline OP
Post Photobucket Reboot from June 2009:
2017 Note; The original image is not available, but if you can ignore my grinning face and look behind, you'll see the result. It works really well.
Dave, it looks like you've shut your Roadster's door with the hood flap shut in the sidescreen??
Surely not? wink
Or is the door just slightly ajar?
Bud
4/4 "Stanley"
DaveW Offline OP
Well spotted. It's ajar.............
Well, it was in June 2009....... innocent
Forgiven then.
thumbs
Bud
4/4 "Stanley"
I would recommend 25mm Cellotex stuck to the inside of the garage door (if not already insulated) Nice and light on the door too.
Specifically designed to eliminate thermal bridges,
The thinnest PIR insulation,
Standard board size of 1200mm x 2400mm, range of thickness
Easy to cut and shape,
Low emissivity foil facings giving improved thermal insulation,
High performance within cavity air spaces,
Long-term energy savings for building
Craig Jezz
