5 members (vincentvg, lez, CharlieB, +8Rich, John V6), 212 guests, and 18 robots.
+8Rich 94
John V6 50
Posts837,998
rockabilly john
#306068 20/09/15 04:56 PM
SteveT Offline OP
So up at the crack of dawn this morning to go to the Bicester Scramble.. Usual prep rigmarole whenever we go out, dog, house locking up, moving cars ( I have a single garage) etc etc..
Get a mile up the road and I find all my dash gauges not working..pull over and check fuses, firstly the diagram on the cover says block A and block B.. Good old MMC, they are the other way round! So finally discover the instrument fuse blown.. A quick change and 2 fuses later reveals I have a dead short.
So nothing to be done but back home and check it out.. Half an hour later I've found the culprit. The dash dimmer! The body of same offending article has 2 flats on it.. Ideally the hole ought to have the same so prevent it from turning.. No.. Again good old MMC in their wisdom just drill a hole. Consequently the whole body of it turns and with it the wiring. So one of the wires(typically the live one) had come off and gone to earth..hence the blown fuses and my lack of any instruments.
So, quickly removed the dimmer and all is well for now.
The dimmer is the nastiest bit of cheap Chinese rubbish available.. Just a look at it and the connectors fall off.. Also clearly the spindle has been hacksawsed off to fit the knob ..just left ragged , not good workmanship I would say on a car that's £40k+.
Anyway, an hour late starting I went off to Bicester, the day wasn't a right off. Got back home and wired in a switch for now so that I have panel lights..
I have an old Lucas potentiometer from a TR somewhere, that'll be better quality for sure ( and that's saying something!) so might use that. I can't be bothered to do anything under warranty, it'll cost more going to and from the dealer and the last thing I need is another rubbish dimmer switch fitted.
Hey ho..
Black Rat
Black Rat
Do you know I don't think I've ever used my dash dimmer, just as well perhaps ooo
Keith
2013 narrow bodied + 4 Ruby.
SteveT Offline OP
No don't touch it Keith!
Also seems daft to me that they wire them to be on all the time under ignition day or night.. Unless you dim them.. And the clock doesn't seem to be in circuit, stays bright.
I shall do it differently.
Very worrying news about the dimmer switch. Why oh why do we keep coming up with examples of very, very poor workmanship with Morgans? They are such brilliant cars and yet, time and again, examples of corner cutting crop up.
You can buy any number of "normal" cars which will run for years and years with no "silly" problems. Are we all daft????
Reg
Reg
It looked pretty crap when you showed me the remains Steve!
As I said....mine is dim or very dim, so much so that I need a torch to check my speed! I'm going to replace it but wonder why there are three wires to it. Anyone got a clue?
Return and Power across the pot then the third is the voltage off the wiper?
Mark - No Longer driving
Mine is OK but then again I never touch it.
Steve sorry to hear you have this in your beautiful plus 4
SteveT Offline OP
John , One is live, one is the 'resisted feed' and the last is ground.
For now I bridged the live in and the out via a switch, full brightness but working.
Formerly known as Aldermog
Surely there is a better way than a 1950s wire wound potentiometer?
Oh yes, it will cost more than a shilling.
I'd had my car for a few months before I discovered I had one. Never bothered touching it since finding it's I can't think why I'd want to dim it!
Roger
