2 members (JMcL, MartO),
328
32
Posts838,016
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
The potentiometer method is fine for controlling the instrumentation used ie it varies the voltage to the easily replaced lamps used in the instruments.
The implementation is the problem.
Probably the value used could do with investigating so that there is more fine control and certainly in the OP's case and probably others the mechanical instalation should be solid
Should I go to the extreme of installing a variable DC:DC converter?
Is it simply that they don't expect people to drive the cars in the dark and wet and that they mostly end up as garage ornaments that these areas get overlooked? Playing on the fuzzy feeling that owning a Morgan is supposed to engender that we will happily overlook things that simply would not be acceptable on other marque of cars?
They maybe based on traditional values and designs etc but this is the age of information and potential owners will be able to easily find out about any shortcomings much easier than any time in the past. Quirks are one thing that people will put up with even find them as part of the character but FAULTS overlooked by the factory are likely to have a detrimental effect on possible sales.
Silly little things like this should not happen.
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Root cause: I am sure that even the cheap and nasty thing fitted would be ok IF the factory made sure that a D shaped hole was made that fitted the switch rather than a round hole .. i.e. its solid and cant turn pulling out wires in the process.
As to why others have dim lights, not so sure. My old TR was the same until converted to LED's.. and I recall the level of control was rather pathetic.. either on or off, not much in between.
Posts: 1,947 |
Most new cars these days seem to have the dash lights on permanently. This seems a retrograde step as we see more wallies that dont have automatic lights driving in the half dark with no lights on. If the dash lights only came on with the headlamps perhaps they would realise they had no lights on when they could not see the speedo. Then again wallies probably dont look at speedos.
