6 members (IcePack, andymog1, Stephen888, ChrisConvertible, TalkMorgan, mph), 232 guests, and 35 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,116
Page 3 of 3 1 2 3
Allon White fitted heated seats in my Mog last year, best investment I ever made ..
Rotary two position switches hidden under the dash.. oops
Peter.
Aero plus8 50th Anniversary.
Get some thermal pants and spend the money on something to make it either go faster or stop quicker.. getcoat
In my case, that would be a good diet - which should also save some spend
laugh2
Formerly known as Aldermog
The Plus 8 has them: with the heater they make open top motoring a real pleasure even when it is cold outside, without the need to put on so many layers movement is almost impossible.
All our cars have them, wouldn't have a car without them now.
You need heated seats in an 8 as I find the heater pretty hopeless. I think it's better for the passenger, but the driver gets almost no heat.
+8 4.8
Try closing the vents behind the radio (there are 3) and make sure the one in the drivers footwell is open. It isn't obvious and you need to use a torch to find it: once you have "learnt: where it is then you won't need a torch!!
I find having just the centre upper vent and drivers footwell one open works well, all the others shut and as long as the fan is on and the heat control fully open. Doesn't do much until the engine has warmed up to 60C plus, about a mile.
Page 3 of 3 1 2 3
