11 members (John V6, Graham, G4FUJ, DavidR, MATTMOG, Sloany, Topline123, DaveW, MartinB60, John07, Redfate, B3MOG), 294 guests, and 39 robots.
+8Rich 64
Adam12 62
John V6 57
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,319
Members9,215
Page 3 of 5 1 2 3 4 5
Thanks a million Robbie,just what I needed pre MOT.
The cheapest I have found is Ebay ( £8.48 for both,includes postage and a further 15% discount for 2 or more)
http://www.ebay.co.uk/itm/361259107251?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
2015 Plus 4 (GDI) Sport Green
Originally Posted By Wirewheel
Thanks for that Robbie, the refills I bought will not do, I will need to buy some blade assemblies.
I bought a pair of 18 inch wiper blades today from Poundland. Just need to source some
Bayonet fittings and then I will have a go at making up some more efficient wiper blades.
Ian
gloomy Wiper Blade Replacement gloomy
Just ordered mine here for the 4/4 - The offside one might need a trim down being slighter longer than required.
Graham
1.8 4/4 Ivory.
Toyota Yarris
Volvo V70 (D5 replaced by D4)
https://moggo-blog.blogspot.com/
I tried these before and cut them down to size -- thay proved no better than the factory standard ones and just spread stuff around on the screen --- hence the "manufactured" ones above which really do work!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
In 11 years of Morganing I haven't found a problem with the standard blades at all even at high speed in the Plus 8's.
I have spent considerable time getting the angle of the crank arm right though such that the blade wipes the screen in a parallel manner. All three of my cars didn't clear the screen very effectively until I played with them.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
Originally Posted By Robbie
Right Folks,
This is the description of the "manufacturing" of replacement wipers: Photos attached.
Buy 2 Bosch 21in Superplus wiper blades - as per the photo attached "Donor Blade" - you need 2 as there are just 2 parts required on a blade and you need 3!!!!
Remove the actual blade from the wiper as per "wiper Disassembled"
Seperate the two smaller parts that grip the blade as per "Part required"
Now -- the tricky bit --carefully open out the centre of the part required so as both sides are parallel and then CAREFULLY drill the middle of the part so as to accept a 2.5mm bolt.
Take the original Morgan wiper blade - "original blade" and punch out the rivet holding the blade clip onto the actual blade so you now have the part that clips the wiper blade onto the wiper arm on the car. Drill out the pivot hole to accept the 2.5mm bolt
now bolt the original clip onto the new "part required" and use a small lock washer under the nut and "Locktite" the nut to the bolt , tight enough to still allow the part pivot.
Cut the new wiper blade rubber to length -- I got 3 new blades from the one donor there is a metal part in the middle of the blade so you need a sharp hacksaw!
you then slide the blade into the holder and crimp ONE of the ends of the holder(part required) -- JOB FINISHED
See the photo "Finished Wipers" in my next post(only allowed 5 files with each post!!) for the car with the wipers fitted. They really are an improvement on the originals
Cheers!
Inspired by Robbie's work I went out and purchased 1 blade, similar to the Bosch but I got the longest I could, 65cm, and that gives me enough for 3 Morgan blades. As it turns out the little supports were held with rivets. The Bosch seems to use some sort of clip.
I carefully punched out the rivet with small jeweller's screwdriver, then carefully tapped the expanded end back to round with a small hammer so that it would go back in the hole. The support had been slightly crushed at that point so it had to be "adjusted".
I then removed the clip rivet from an old Morgan wiper using a Dremel tool and then opened the holes slightly to take the saved rivet from the donor blade. I fitted it all up and then peened the end of the rivet, and slightly squeezed the grips. The steel strips can be removed from this blade and re-inserted in the grooves. I used a very good wire cutter to start the cut and then when I flexed the very hard spring steel, whilst gripped in the wire cutter, they just snapped at the desired point.
After I fitted it to the car I adjusted the position by moving the blade in the grips so that it just cleared the bottom of the windscreen frame at the end of the wipe.
Here is the result before I fitted it to the car.
Nice work Peter.
Imitation is the best form of flattery!!!! Well done, Peter, exactly the right outcome!!
Cheers!!
Robbie
211-WX-1433
Thanks for the inspiration Robbie.
I had actually purchased a set of lovely Trico Aeramic 285 mm chrome (stainless) blades that suit a raft of Italian and English cars of the 60s. They are a work of art but I could not quite work out how to modify them. The only thing I can think of is to carefully cut and glue the back shells to get the correct dimensions.
Don't be fooled by the curved shape. The centre rivet holds a spring loaded pivot point and the blade becomes flat under load.
Mine are old Italian stock but they are still made.
http://www.tricoproducts.com/Trade/WiperProducts/MoreProducts/Classic
This is a sort of failed experiment. I have not entirely given up but the blade does not wipe as well as the Robbie's system which works perfectly. I think the spring loaded back shell is putting too much force on the tips and the blade is not going completely straight on the flat glass.
This shows the blade dismantled
Cut to length and with the sections holding the "claws" waiting to be epoxied in place.
The finished shortened blade. Note that the back shell is spring loaded in the middle and that the blade comes straight under pressure of the wiper arm.
On the car. Robbie's blade is in the middle. The stainless looks good but there is not enough pressure on the centre section to hold the rubber straight.
