3 members (Montegue, Chris Cosher, JohnHarris), 213 guests, and 37 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Page 2 of 14 1 2 3 4 13 14
Brilliant...not long now
I spy a new style handbrake ?
nippymog #309005 01/10/15 02:11 PM
Tell me more
The business end is white and flat topped.
Mine is metal and domed.
Could be a protective cover thinking about it , but a bit over the top if it is !
It is exactly that...a bit of protective tape. Don't get excited!
Daft question coming up - first time I have seen a 3 wheeler build. Is there a reason that a belt was used rather than extending the drive shaft and bolting the wheel to the bevel box?
Looks great and amazing that jays can get pics on TM of scotts build.
Great stuff!
kwb Offline
If you build it as you described there would be no suspension for the rear wheel which could be somewhat strange.... If you introduce a suspension using your vision you needed some way to move the bevel box up and down, making sure it holds track etc.
Karl
Life is hard in the mountains
2009 silver +4, 2013 red C4P, 2014 yellow M3W gone to a new owner
kwb #309095 01/10/15 07:30 PM
Wouldn't that then be a shaft drive?
Red Leader drive
The forerunner to the M3W, the Liberty Ace, had a shaft drive via a Honda Goldwing (at least I think it was a Goldwing) shaft and swing arm. If you do a bit of searching for photos of its interior you'll see that the transmission tunnel was set at an angle so that the back part of the shaft could clear the tyre. What this meant was the passenger side of the cockpit was narrower than almost any human being and that it would be almost impossible to economically re-engineer it for right hand drive.
RedThree #309122 01/10/15 08:51 PM
Yes, this was certainly a crude design, but it is possible a shaft design could have been engineered more effectively without eliminating passenger space. My assumption would be that the final Morgan design was probably the cheaper option (and possibly lighter)
