0 members (), 206 guests, and 86 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 3 of 3 1 2 3
Finally found time to investigate this and it turns out that the gasket was kinked. This in itself wouldn't necessarily be a problem but it had also developed a hairline split - presumably because it was under tension. frown
To my knowledge, the rocker cover hasn't been disturbed since new so I guess it was sloppy assembly at the S&S factory? Or maybe a batch of out-of-spec gaskets? I think I'll check the other side just in case...
Andy
Sounds like a simple fix....
Be careful with these head bolts , S&S specify some very specific torque settings and tighten up sequence for these. Details on their website.
The new seals are made of aluminum coated with a Teflon kind.
Page 3 of 3 1 2 3
