5 members (andymog1, ChrisConvertible, TalkMorgan, mph, chanteclair), 244 guests, and 22 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,116
Can anyone tell me the size of the plate holder on the rear so I can get a plate made to fit
Thanks Scott
L 165mm x 150 mm h
Thank you very much
The paint is peeling off my rear numberplate holder/boot hinge/brake light holder after 3500 miles. The paint doesn't seem to stick to the sharp edges of the steel parts. Anyone else had this?
Andy
Only on my headlamp mounting brackets, also on the sharp edges. Poor powder coating I expect.
My headlamp brackets flacked. I needed a new R/H haedlamp so bracket, lamp & indicator changed as unit & L/H bracket only, all warranty work.
Yes, I had the same problem with my headlamp brackets so MMC kindly replaced them under warranty. This also had the bonus added effect of providing more (read 'some') clearance between the front indicators and the top wishbones. smile
Andy
Had mine replaced under warranty but now out of warranty and the second set have gone the same way.
I'm hoping ACF50 will keep the paint lasting longer on my new brackets
Powder coating a relatively sharp edge is awkward. A thick component can have a chamfer added to help, but a thin sheet part like a headlamp surround is always going to be a problem.
2012 G56 Stage 2 M3W
2007 Fiat Panda 100HP
1998 Lotus Elise (Cosworth Duratec)
1988 RF88 Van Diemen
