Morgan Aero 8
6 members (bmgermany, Grumpy2, Mkiss, Mats, Burgundymog, MJF), 205 guests, and 69 robots.
+8Rich 76
Topics49,863
Posts837,548
Page 1 of 4 1 2 3 4
#313293 20/10/15 04:45 PM
Peter J Offline OP
Formerly known as Aldermog
Sitting outside Williams today was a sad looking red Plus 8.
The owner cracked the sump on someting in the road, lost oil and before oil pressure was lost the lack of oil flow has caused damage to the VANOS system. Seems the oil pickup is rather easily damaged it the sump is damaged and that the VANOS system is driven by oil pressure....!
I was told the car has to go back to MMC, Engine out, new sump, re-set up the VANOS timing. At least £1500 labour, plus parts.
Wonder if insurance covers that!
So, the ground clearance is better than a Roadster, but the risk is still there....!!
Peter J #313295 20/10/15 04:53 PM
Wonder if a sump guard would be a good idea?
Andrew
'Alice' 2013 Duratec Plus 4. Pearl Blue
Andrew255 #313297 20/10/15 04:54 PM
Peter J Offline OP
My thought too.
Cain? Where are you?
Peter J #313301 20/10/15 05:05 PM
Sump guards are fine, but they reduce ground clearance. And unless they are robust, they will still bend when impacted. They also reduce airflow, so where the sump plays a role in cooling the oil, the cooling effect will be reduced.
On the Trad there's a chassis to bolt one to, but on the Aero?
It would need a proper design.
Peter J #313304 20/10/15 05:09 PM
The sump is not low and it sits above the front cover plate, so it must have some object in the road.
Martin (Deano)
Peter J #313305 20/10/15 05:10 PM
Had a sump guard on my first mini when I thought I could be a rally driver, I couldn't. Took a massive hit one day and the engine was fine but the silencer fell
off!
Andrew
Andrew255 #313308 20/10/15 05:13 PM
off!
I remember those days, good fun.
Martin (Deano)
Peter J #313321 20/10/15 05:35 PM
I also had a Mini with a quarter inch plate bolted to the subframe. Somebody had drilled a load of holes in it for ventilation I suppose. You could jack the car up on the sump guard.
But changing the oil was dodgy.......
Peter J #313330 20/10/15 06:21 PM
Snow plough on the front should clear any road debris!
Mark - No Longer driving
Peter J #313332 20/10/15 06:38 PM
Ray Offline
The Australians and Americans, can use their cow catchers off the locos.
Page 1 of 4 1 2 3 4
