12 members (MogOnTheMove, John07, Rex_tulips, PaulyG, RedThree, linklaw, brownbaker, Richardllll, Ian Wegg, Dek, Grumpy2, Vansrv6),
306
New
Topics48,365
Posts813,384
Members9,215
Posts: 26,763 Likes: 425
Posts: 26,763 Likes: 425 |
+1 the combo with the ST220 works really well.
Posts: 4,896 |
When I moved from +8 to Roadster one off my key criteria set was better seats that I could adjust the recline. This was an optional extra on the earlier cars. If you are going to drive more miles or tour I would recommend you take this into consideration. Just being able to change the incline seat every now and then can make a big difference.
Adrian
Posts: 215 |
Do you guys have cars with high mileage (70.000 and above) or have knoweldge of high cost maintenance on cars driven far?
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
You might be better searching the ST220 and Jaguar X Type and S Type forums (if there is such a thing). I'm not aware of any engine issues over large mileages, but the dual mass flywheel is a known weak spot on cars which have it.
Sorry no my car is at 16.6 k miles
I have the non reclining buckets seats & SWMBO & I find them just fine bit a pain to load the back shelf.
Posts: 989 |
My 2002 auto s type jag has the 3.0 v6 and has now covered 96k and no issues at all with the engine. Ved in the jag equates to 290 per year. Its ample power in the heavy jag so would imagine ina morgan it'd fly! I would imagine it commands respect in a light weight sports car, a bit of a handful ?
Mpg in the jag is ok too @ 26-32 depending use, again the Morgan likely to be better.
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 215 |
is it a standard Duratec 3.0 or 3.7l or has Morgan made changes to the block?
As far as I know it's standard Duratec.
