5 members (Mats, Burgundymog, Mkiss, bmgermany, MJF), 188 guests, and 67 robots.
+8Rich 76
Topics49,863
Posts837,548
There is no Gemmer Box anywhere aviable.
I need one, my is defekt.
+8 1976
A couple of thoughts related to the original post.
Firstly I have a copy of a page produced by Bill Button in the states about his conversion of a 1960's +4 to a Gemmer box. He uses a TR7 upper column and a Jag XJ6 steering rod connected with an MGB universal joint. A big hammer is used to adjust the inner wing!
Secondly if the concern is just about the long column, wasn't the early +8 steering box the same as the early +4 but with a split column. I bought one from a Miscellany ad a while ago because at some point in the future I wish to upgrade the steering on my 1966 +4
Malcolm T
1966 +4
1957 TR3
1963 TR4
1983 LR 110
1985 Robin Hood 2.0l
Thank you all for support. Based on the your advice I will start with checking the box I have and – if it isn´t OK – try to find a Gemmer. Where can I get such one?
Christer
As I understand it LHD Gemmers are unobtainable.
if it ain't broke, fix it 'till it is.
'72 4/4 4 pass
'52 +4 roadster (Shillelagh)
Have you tried talking to Terry Foxen at GEE? If he hasn't got one, there's always the option of getting a local engineering company to re-make the worn bits.
There's a small engineering outfit run by some pals of mine in the same building as Terry that quite often make parts for him. You could probably find somewhere close to you that could do the same.
If it were me, I would take the steering box and go to your local industrial estate and start asking around for small engineering companies that do one-off jobs. If Germany is anything like the UK you'll find plenty of them in every town. Somebody will have look at the box, figure out what needs doing, and if it's not something they can do they will recommend someone that will be able to help.
In my experience I have found that they all know each other, they each have their own specialist skills, and they work together in an informal network to get jobs done. The more interesting or different the job is, the more helpful they are.
The original Burman steering box is a simple device and easy to strip down. It is made up of a worm (on the shaft) a peg that locates into the worm, some cage bearings and some shims.
Do you know what the defect is with your steering box?
E
E
I have tried to remove the drop arm off my steering box with a hefty puller but to no avail so I think I will be sending it to ICS in Birmingham for a re-build.
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
