0 members (), 169 guests, and 74 robots.
+8Rich 63
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,761
Page 5 of 9 1 2 3 4 5 6 7 8 9
JVS Offline OP
next up is taking out the rubber isolation mount.
just need to unbolt the three darker Allen heads
[img:center]http://postimg.org/image/bbntfh28f[/img]
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
JVS Offline OP
[img:center]http://postimg.org/image/73xmkgq6n[/img]
JV Sclafani
Boca Raton, FL
JVS Offline OP
next up is the compensator cover.
we used one bolt to attach the slide hammer to it.
it came off easy
[img:right]http://postimg.org/image/kyvx2xklr[/img]
JV Sclafani
Boca Raton, FL
JVS Offline OP
you can see the greased up Harley Davidson direct drive damping compensator inside all that grease.
we did clean it all up to find that Morgan used this 1984 HD setup.
It's all in good shape.
[img:center]http://postimg.org/image/rduxzlrbj[/img]
JV Sclafani
Boca Raton, FL
JVS Offline OP
compensator out [img]http://postimg.org/image/ol1qfkqz3[/img]
JV Sclafani
Boca Raton, FL
JVS Offline OP
We saw some rubbing - grinding from the compensator housing against the coil housing?
we'll have to look at that soon
JV Sclafani
Boca Raton, FL
JVS Offline OP
the 1984 HD compensating sprocket diagram.
It's the bottom diagram
we are working on modifying this setup since it works better with my hot rod style of driving.
JV Sclafani
Boca Raton, FL
JVS Offline OP
I'm hard on equipment!
but what gets me is, it's only 80HP, lightweight and just spinning a tiny 175 wide tire and I'm tearing up all the clutch parts and drive spindles? WTF it should take this kind of beating!
JV Sclafani
Boca Raton, FL
Interesting read JVS. Thanks for sharing.
Thanks for all the info and photos JVS, interesting as there is very little information on this about. My view is that the Centa unit will take more punishment without destroying itself than the HD unit. It is certainly much better to drive normally with, although maybe a bit more transmission vibrations under some conditions. Later cars have a heavier clutch pedal, and I assume matching heavier clutch diaphragm, that may reduce the possibility of the clutch burning out as well. Looking forward to all the re-assembly stuff. Good luck!
