Topics49,859
Posts837,471
Posts: 676 |
On new Morgans as well as the Cuprinol dip for the woodwork is there any further treatment applied to the wood such as a waxoyl (or similar) type treatment?
1989 911 Porsche Carrera Land Rover Series Defender 90 SW
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Some wood bits are covered in a thin layer of aluminium for extra protection
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Edgar1969 4/4, As far as I can see, all the visible woodwork in my car is covered with the black "underseal" that the whole underside has been treated with.
Reg
Reg Same on mine Particularly noticeable when I took the spare wheel off the back of my 4 seater and the wood crossmember and frame work exposed had been coated in the black underseal stuff
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
At the moment the Black Dinitrol 4941 is sprayed liberally over the underside, and inside the spare wheel hole. The transmission tunnel is masked off. It's very effective at keeping the water out, but I prefer the earlier golden wax underseal (ML3125?)which the factory used around 2005. https://dinitrol.co.uk/ClassicCar.aspx
Posts: 676 |
Thanks for the answers Gents. I'll look at Dinitrol (golden wax) when I need to treat the new woodwork.
