7 members (Hamwich, chanteclair, Ian Wegg, High Hamster, Luddite, Clipper, Bishmog), 278 guests, and 35 robots.
John V6 70
DaveW 67
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,012
RedThree
Page 8 of 9 1 2 3 4 5 6 7 8 9
JVS, I just realized that you're in Florida. It's good to know someone with your expertise is not too far away.
Originally Posted By JVS
I'm lucky enough to belong to a small car club where we build and fix our own cars and bikes so this has been a fun project getting to know English mechanical thinking along with brushing up on our wood working skills :-)
Good god, I wouldn't use a M3W as any measure of contemporary English mechanical thinking!! Morgan Design did a great job of styling the car (almost perfect in my opinion, for what the wanted to achieve) but mechanical implementation was, erm, 'less perfect'. There are certainly much better examples of English mechanical design out there....
2012 G56 Stage 2 M3W
2007 Fiat Panda 100HP
1998 Lotus Elise (Cosworth Duratec)
1988 RF88 Van Diemen
2013bluem3w,
Are you in South Florida too? I wonder how many others might be nearby.
Bill in FtL
2013bluem3w,
Bill in FtL
I'm in the Orlando area, so unfortunately I'm not too close.
JVS Offline OP
anyone that wanted to see how to assemble and install a new upgraded Centa compensator onto the S&S motor please check out this post called.......
Install a new Centa Compensator unit
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
JVS Offline OP
the clutch slave was very easy to replace.
Unclip the brake fluid tube and pull it off
(because of the brake fluid getting everywhere.
unbolt the old unit and bolt in the new unit
reattach the hose and clip
http://postimg.org/image/jaldj049b/
JV Sclafani
Boca Raton, FL
JVS Thank you so much for all the work you have done setting up the pictures and info for the Forum. I hope this will all go into the Workshop Manuel that is currently in process
Thanks again!
JVS Offline OP
My pleasure!
I thought this would be great for those owners that are too far away from factory service and for those that are mechanically inclined to do their own work.
JV Sclafani
Boca Raton, FL
Huge thanks for all this effort!
JVS Offline OP
Time to put the new clutch pack onto the engine.
First clean up the flywheel bolts
Attach the Flywheel to the engine shaft
80 ft lbs of torque on the bolts
We have a tool that can hold the flywheel from turning as you torque the bolts down.
It's a Snap On Tool A-144 Flywheel holder
Next up is the pressure plate - it has a label on which side faces the flywheel.
****Next is a critical Step **** (sorry no picture)
Using the pilot shaft ailment tool to center the clutch plate splines on the crankshaft.
Note: Without it being aligned to the pilot shaft correctly when going into the pilot shaft, it could damage the previous installed pilot shaft bushing!
Metric Clutch Alignment Tool need to do the job right
Torque pressure plate to flywheel at 25 ft lbs
the pilot shaft bushing that was installed with a small press before it was installed into the compensator part of the engine.
When bolting on the transmission tunnel:
No Lock tight to be used on these bolts
Be sure to use a small lock washers
Torque to 28 ft lbs
JV Sclafani
Boca Raton, FL
