Topics49,839
Posts837,301
Posts: 782 |
Deluxe sealed structure to prevent moisture ingress New chassis mods to stiffen car further and allow larger driver / passenger Modified screen Modified rollover hoops Racing upgrades - engine, brakes, cooling, shocks More supportive seats Modified rear catches for luggage opening
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Ah, it's become a large wish list now, then!
A 'Heritage' edition, with (amongst others) a rear mudguard as a standard item is my minimum bet..
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
20% price reduction for loyal customers.
Martin (Deano)
Posts: 303 |
Posts: 303 |
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Improved airflow over the front brakes They are pretty much in the fresh air - how much more cooling do you need I suspect it'll be pretty much paint and graphics options with the dev effort spent on the leccy version.
Red Leader
Posts: 1,562 |
Improved airflow over the front brakes They are pretty much in the fresh air - how much more cooling do you need Oulton Park trackday earlier this year , keeping up with the others. Check out the colour of the discs. Nothing binding before we go down that chestnut. Just braking as hard as I was accelerating ...
Posts: 782 |
In that case...
Stabiliser bars to limit incidence of car inversion under track conditions
Much bigger roll hoops
Cushions in front of driver and passenger instead of airbags ie. continually deployed airbags
We should all get jobs at the factory after this lot!!
Posts: 306 |
Well this is all about the MTW. What is going to happen when the V8 engine goes.
Dave
1997 Plus 4, Metalic Blue. 2000 Toyota Yaris. (The Tardis)
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
They have created more room under the bonnet with the new conventional front suspension, so there may now be room for a straight six if MMC stay with BMW.
Wasn't the EVA down for a straight six or am I mis - remembering?
