7 members (B3MOG, TBM, Doug J, Dek, MJF, Guern, Ian Wegg),
221
75
Topics49,861
Posts837,531
Posts: 4,896 |
No substitute for three ears, and one more place to hit....... 10 points off for loosing originalitity  they do look good though
Adrian
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
I prefer the cleaner look of the "hex" ones. +1
Posts: 8,646 |
or maybe you should go for the one eared spinners (like Bodicea).....
Giles. Mogless in Paris.
Could have done with them several times on the M5 this week Giles!
Posts: 543 Likes: 2
Posts: 543 Likes: 2 |
Two eared with a plain finish!
Posts: 82 |
2 eared spinner arrived yesterday 👍 and installed them today But when installing noticed a bit of play on front richt wheel bearing So question ? Can you adjust this or need for changing? Play in bearing is in and out not up or down or sideways difficult to ew plail Gr tom
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
You could check the tightness of the castellated nut (remove split pin first) but don't over tighten.
Richard 1976 4/4 4 Seater
Posts: 82 |
What do i need to remove to reach the castelhaed nut ?and witch tools do i need to finish the job Gr tom
Long nosed pillars to remove the split pin - rotate the hub until a small hole in the hub aligns. You may need to remove some grease to fin the hole. Socket over the nut and see if you can tighten it - DO NOT OVER TIGHTEN as you will make it harder for the bearings, they then may seize and fail.
Then refit the split pin (ideally with a new one). This is the hardest (most fiddly) part.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
Then refit the split pin (ideally with a new one). This is the hardest (most fiddly) part. I'd remove the brake caliper and disc and have a look at the condition of the outer bearing while you're at it.
1972 4/4 2 Seater
