1 members (BHV), 265 guests, and 43 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
peterd Offline OP
After 5 years morganeering (2009 +4 Anniversary), I could't see more the ugly standard steering column cover, covering almost the whole nice Moto-Lita boss. After shortening the original cover, the space between the boss and the cover must be closed. Originally I wanted to make the cover of a stainless steel sheet, however, this is difficult to cut. After a longer inspection of materials rests in the workshop, I found an old plate used for electronic schemes (semiconductor board?), which has one side covered by copper. This material is easy to process and can be very good glued with superglue, direct on the narrow cut of the shortened basis cover. I leveled the cut plane on a glass-plate covered with sandpaper.
The amount to shorten the original cover should enable to position the new made cover at the middle of the first boss indentation. Then, the hole diameter can be cut just 2-3 millimeters larger then the indentation diameter giving tight fit between the boss and the cover.
So, practically zero costs, just the cutting and adjusting exact shape takes time and requires patience, exact measuring and working. The original plan was to cover the whole piece with leather or spray the new part black. Then I tried to polish the copper – it looks not bad and the polished copper harmonizes well with the surrounding.
Pretty mod., must see what I've got in my shed...
2011 +4 'LB' Indigo Blue, Heron trim
Saab 9-3 1.8T Sportwagon
Very good idea - and looks perfect too!
The Leather version from Dealers costs £200! scared
Neil
I wonder what happened to the aluminium side panels from PCB card frames I used to have? I suspect it is all used up. Bother.
This is a great idea and I suspect you have started something now.
Costock, UK
Disco 5
Very neat job. Well done.
Ian
Drive on the Wild Side
A nice and well made improvement.
Adrian
Tidy work.
Peter, good improvement! Well done.
Kind regards,
BertR
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
+1. Fancy making me one?
That is really lovely...... thumbs
1975 4/4 4 seater, cream over blue; Q3 Quattro; Bicycle; Walking poles.
