7 members (DaveW, Moggo, Calypso Red, AndyGoff, sprinty, Image, BobtheTrain), 321 guests, and 90 robots.
Topics49,847
Posts837,389
Page 2 of 6 1 2 3 4 5 6
I
I
Wait.
A flat bottomed steering wheel...even on an Audi...makes as much fashion sense as wearing suspenders with a belt, so there's absolutely no way one of those will ever grace any of my cars, and most especially a 3. Please tell me my time here hasn't resulted in my being perceived as a total dork.
As I said originally, I personally like the 15" wheel and wanted to know if anyone had experience with one in a 3 and if they found the thigh clearance OK, and what I'm hearing is that it should be OK..right?
14" Brooklands is fine for me...
(could also accept 13" as the 3W is lightweight)
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
With a 14 inch wheel, you can use the tonnuae cover with the wheel in place, with a 15 inch wheel, you must remove to use the tonnuae cover (when parked of course).
The standard wheel is 14" and I've replaced mine with a 13" Moto-Lita.
The extra thigh room is noticeable and welcome.
I'd not recommend going up a size if you're over 6'.
Red Leader drive
I
I
I Hadn't considered the tonneau issue...it's that tight that it won't fit a 15"?
I'm probably over thinking this, but the standard wheel just didn't work for me, not only was it just too dark, but too thick and too small. I know it's personal taste, but 13" wouldn't work for me at all.
I saw a 4/4 at the dealer with the four spoke Moto, 14", and it looked too small to my eye. This is unusual for me, b/c typically I like a smaller wheel, I actually went thru the considerable job of installing a 14" Nardi on my Alfa this past summer, down from the std. 15", and it looks much better with a smaller wheel.
But if the 15" will scrape my lap whilst driving, that would be a deal breaker. The tonneau fit, maybe not.
Does anyone have a 15" wheel?
I'm about 5'10" and weigh about 170 lbs. l currently use a dished 15 inch dished wheel and the only issue is having to pull the wheel when I put on the tonneau. Having said that, I just found a Brooklands type 14 inch wheel with three spokes instead of four that I am going to try.
HJP Offline
I have aa 4 spoke 15" wood rimmed motolita wheel and really like it , it is slightly tight under the tonneau but not a problem .
Hugh
I
I
This is on a 3? Could you kindly post a pic?
And it's not tight on your lap?
HJP Offline
It is on a 3 wheeler , I don't find it a tight fit but then I'm pretty thin !
I'm afraid I've yet to master picture posting ..... hopefully someone else can post one .
Hugh
14" Brooklands, visibility of instruments
(LHD as you may recognice)
Hannes
