0 members (), 226 guests, and 78 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Thanks Nippy
Originally Posted By MarioCP
I'm making a change to my "European model", ordered the slightly higher roll hoops (Aussie Spec) for my M3W.
They'd be installed by now, but MMC sent me two equal roll hoops ... as in ... two roll hoops for the same side of the 3W, and none for the opposite side. laugh2
That is an option I am considering, but how much taller are they??
kirkusblog.com
1952 Ford 8N
Q
Q
Why are you considering them? The standard m3w looks propositional all around..
About 240mm measured in the centre of the hoop (its on a slope!) Means the padding is in the middle of the back of your head which is much safer than the standard ones where the top of the hoop is level with the back of your head. Think about it if you get shunted the centre of the metal hoop in the back of your head - much safer the padding!
My thoughts are that if I go with the Fairburn carriages GT Aero screen then the taller hoops would look more proportional?
kirkusblog.com
1952 Ford 8N
Q
Q
Aha can you post the " fairburn carriages gt aero screen" first for me
http://www.fairbournecarriages.com/index...0&Itemid=65
kirkusblog.com
1952 Ford 8N
Q
Q
You are definitely on point, you will need the higher roll bars. Good luck
