Before you go in under the dash, just park the car on a slope facing downhill and tie a length of rope to your ankles, secured to something handy like a lamp-post. Tie a longer rope to the car, secured in the same way.
Then when you have finished work, just get a passer-by to release the handbrake. The car will roll forward until arrested by its rope. Meanwhile your rope, being shorter, will draw you smoothly out of the footwell, depositing you on the road behind the car.
Simple!
Simple!
Or change to a 2003 "poverty model" 4/4; where all the fuses and relays are neatly located and easily accessible in a box under a the bonnet.
That is where the bl00dy things should be, or in some other easily accessible place. Having to remove the dash to get at the relays is just ridiculous!!!!!!
A typical pair of Budster photos (i.e. not very good) but should show the "poverty" fuse/relay box both open and shut.
As for Tim's suggested way of getting out having fixed the issue on newer models; I am slightly concerned about the potential risks of the high level "cyclops" brake light.
Is that a 4/4? - Does not look like mine under the bonnet.
Cunning adjustment of the relative lengths of the two ropes should ensure that the car is moving quite fast when the second rope tightens, thus ensuring a clean 'snatch' of the occupant from the footwell, and a relatively high arc of travel should ensure no bodily contact with the rear of the car.
An astute mechanic would of course recognise the impending removal by the sensation of tightness around the ankle, and thus be prepared to ensure a safe landing. No doubt a small jury of other Morganeers could be on hand maybe to award points for cleanliness of exit, neatness of landing, and overall artistic interpretation during flight.
