5 members (GrumpyPa, PaulV, Jon G4LJW, Plus Four Guy, IcePack), 273 guests, and 20 robots.
+8Rich 95
John V6 52
Posts838,002
rockabilly john
#319508 16/11/15 12:53 PM
Can anyone give me any tips as to where Morgan might have hidden the relays on my car? And no, they're NOT on the bulkhead!
2011 +4 'LB' Indigo Blue, Heron trim
Saab 9-3 1.8T Sportwagon
Mike Carter #319509 16/11/15 12:56 PM
On 2011 ' s they are likely to be under the dash fairly central and screwed into the bulkhead frame.
On 2005's they are above the steering column.........
DaveW #319513 16/11/15 01:28 PM
Oh gods, could they have made them any harder to get at? Thanks for the tip :-)
Mike Carter #319524 16/11/15 02:32 PM
It is not so difficult if you look under steering wheel you can see them
John V6 #319544 16/11/15 04:21 PM
Yes.....crawl into the car, turn over, lie down with your head in the footwell, torch between your teeth, and you'll find them.
Mike Carter #319559 16/11/15 04:53 PM
Is it worth taking the top of the footwell off to get to them? Only seems to be 4 screws holding it in place...
Jays #319565 16/11/15 05:19 PM
Ray Offline
Easy, but who gets you out again?
Mike Carter #319568 16/11/15 05:28 PM
Keep mobile phone within reach !
Mike Carter #320306 20/11/15 07:00 AM
The dashboard is held on my 4/4 by just three screws. one at either end and one high up, centrally lurking below the rubber top trim. Lower the adjustable steering column to its lowest travel, Remove undertray. lift off the dash complete with all its instruments and support the weight with string or something suitably wedged under. The relays are then obvious and easily accessible. coffee
Graham
Octogenarian - (83)
1.8 4/4 Ivory
Toyota Yar.
VolvoV70
Mike Carter #320323 20/11/15 08:57 AM
Or change to a 2003 "poverty model" 4/4; where all the fuses and relays are neatly located and easily accessible in a box under a the bonnet.
laugh2
Bud
4/4 "Stanley"
